=== 采集于 2026-11-23 15:17:37 CST ===
本目录为只读快照，回帖时建议整个目录打包上传。
--- DDE 侧 ---
[AirplaneMode1.GetAll —— 飞行模式 / WiFi / 蓝牙三路属性]
({'WifiEnabled': <false>, 'BluetoothEnabled': <false>, 'Enabled': <false>, 'HasAirplaneMode': <true>},)
[AirplaneMode1.WifiEnabled]
(<false>,)
[Network1.IsDeviceEnabled(wlp3s0)]
错误：GDBus.Error:org.freedesktop.DBus.Error.Failed: not found device
[Network1.IsDeviceEnabled(enp2s0)]
[AirplaneMode1 接口内省（只读）]
NAME                                TYPE      SIGNATURE RESULT/VALUE FLAGS
--- NM 侧 ---
[nmcli device status]
DEVICE          TYPE      STATE         CONNECTION
enp2s0          ethernet  已连接        有线连接
lo              loopback  连接（外部）  lo
virbr0          bridge    连接（外部）  virbr0
wlp3s0          wifi      已断开        --
p2p-dev-wlp3s0  wifi-p2p  已断开        --
[nmcli radio all]
WIFI-HW  WIFI    WWAN-HW  WWAN
已启用   已启用  missing  已启用
[nmcli radio wifi]
enabled
[nmcli device show (wifi 接口)]
GENERAL.DEVICE:                         wlp3s0
GENERAL.TYPE:                           wifi
GENERAL.HWADDR:                         B6:1F:1C:CA:64:A2
GENERAL.MTU:                            1500
GENERAL.STATE:                          30（已断开）
--- rfkill wlan（找 type=wlan 的那一段）---
type=wlan
state=1
hard=0
soft=0
[/dev/rfkill]
crw-rw-r--+ 1 root root 10, 242 11月23日 15:02 /dev/rfkill
[rfkill list]
--- 启动时序 ---
[systemd-analyze 启动耗时]
Startup finished in 7.307s (firmware) + 6.033s (loader) + 5.820s (kernel) + 1min 28.532s (userspace) = 1min 47.695s
graphical.target reached after 1min 28.510s in userspace.
[关键单元启动时刻]
--- NetworkManager.service ---
ActiveState=active
SubState=running
InactiveExitTimestamp=Mon 2026-11-23 15:02:24 CST
ActiveEnterTimestamp=Mon 2026-11-23 15:02:24 CST
--- bluetooth.service ---
ActiveState=active
SubState=running
InactiveExitTimestamp=Mon 2026-11-23 15:02:23 CST
--- deepin-service-manager.service ---
ActiveState=active
SubState=running
--- dde-daemon.service ---
ActiveState=inactive
SubState=dead
--- 本次启动网络相关日志（前 20 行）---
2026-11-23T15:03:48+08:00 pc4w deepin-service-manager[5262]: QCommandLineParser: already having an option named "h"
2026-11-23T15:03:48+08:00 pc4w deepin-service-manager[5262]: QCommandLineParser: already having an option named "help-all"
2026-11-23T15:03:50+08:00 pc4w dde-application-manager[5263]: dde.am.manager: couldn't find app "deepin-service-manager" in application manager.
2026-11-23T15:03:50+08:00 pc4w dde-application-manager[5263]: dde.am.manager: couldn't find app "sys-devices-virtual-misc-rfkill" in application manager.
2026-11-23T15:03:50+08:00 pc4w dde-application-manager[5263]: dde.am.manager: couldn't find app "dev-rfkill" in application manager.
2026-11-23T15:03:50+08:00 pc4w dde-application-manager[5263]: dde.am.manager: couldn't find app "sys-devices-pci0000:00-0000:00:02.2-0000:03:00.0-net-wlp3s0" in application manager.
2026-11-23T15:03:50+08:00 pc4w dde-application-manager[5263]: dde.am.manager: couldn't find app "sys-subsystem-net-devices-wlp3s0" in application manager.
2026-11-23T15:03:50+08:00 pc4w dde-application-manager[5263]: dde.am.manager: couldn't find app "dev-disk-by-partlabel-EFI\\x20system\\x20partition" in application manager.
2026-11-23T15:03:50+08:00 pc4w dde-application-manager[5263]: dde.am.manager: couldn't find app "dev-disk-by-partlabel-primary" in application manager.
2026-11-23T15:03:50+08:00 pc4w dde-shell[5793]: Topic  "dfmplugin_sidebar" : "signal_ReportLog_Commit" is invalid
2026-11-23T15:03:50+08:00 pc4w dde-shell[5793]: Topic  "dfmplugin_workspace" : "signal_ReportLog_Commit" is invalid
2026-11-23T15:03:50+08:00 pc4w dde-shell[5793]: Topic  "dfmplugin_workspace" : "signal_ReportLog_MenuData" is invalid
2026-11-23T15:03:50+08:00 pc4w dde-shell[5793]: Topic  "dfmplugin_sidebar" : "signal_ReportLog_MenuData" is invalid
2026-11-23T15:03:51+08:00 pc4w dbus-daemon[2962]: [session uid=1000 pid=2962 pidfd=6] Activating via systemd: service name='org.deepin.dde.Appearance1' unit='deepin-service-manager.service' requested by ':1.76' (uid=1000 pid=5793 comm="/usr/bin/dde-shell -p org.deepin.ds.desktop" label="unconfined")
2026-11-23T15:03:51+08:00 pc4w uos-ste-resourc[5246]: Slice path does not exist: /sys/fs/cgroup/user.slice/user-1000.slice/user@1000.service/session.slice/deepin-service-manager.service/memory.wmark_step
2026-11-23T15:03:51+08:00 pc4w deepin-service-manager[5946]: dtk.core.dsg: Identify from AM failed: can't find application:deepin-service-manager
2026-11-23T15:03:51+08:00 pc4w deepin-service-manager[5946]: QCommandLineParser: already having an option named "h"
2026-11-23T15:03:51+08:00 pc4w deepin-service-manager[5946]: QCommandLineParser: already having an option named "help-all"
2026-11-23T15:03:51+08:00 pc4w deepin-service-manager[5946]: set service path failed, the object is existed:  "/org/deepin/ServiceManager1"
2026-11-23T15:03:51+08:00 pc4w deepin-service-manager[5946]: set service path failed, the object is existed:  "/org/deepin/ServiceManager1/Private"
=== 看什么 ===
1) DDE 侧 WifiEnabled / Network1 设备表，与 NM 侧 WirelessEnabled / nmcli radio 是否矛盾
2) wlan 的 rfkill 是否 hard=0 soft=0（若被屏蔽，方向就不同了）
3) 06 里 deepin-service-manager 与 NetworkManager 的 ActiveEnterTimestamp 谁先谁后
4) 日志里有没有 EnableWifi / 飞行模式切换 / 手动关开关的记录
