# CMAKE generated file: DO NOT EDIT!
# Generated by "Unix Makefiles" Generator, CMake Version 3.31
# Default target executed when no arguments are given to make.
default_target: all
.PHONY : default_target
# Allow only one "make -f Makefile2" at a time, but pass parallelism.
.NOTPARALLEL:
# Special targets provided by cmake.
# Disable implicit rules so canonical targets will work.
.SUFFIXES:
# Disable VCS-based implicit rules.
% : %,v
% : RCS/%
% : RCS/%,v
% : SCCS/s.%
% : s.%
.SUFFIXES: .hpux_make_needs_suffix_list
# Command-line flag to silence nested $(MAKE).
$(VERBOSE)MAKESILENT = -s
#Suppress display of executed commands.
$(VERBOSE).SILENT:
# A target that is always out of date.
cmake_force:
.PHONY : cmake_force
# Set environment variables for the build.
# The shell in which to execute make rules.
SHELL = /bin/sh
# The CMake executable.
CMAKE_COMMAND = /usr/bin/cmake
# The command to remove a file.
RM = /usr/bin/cmake -E rm -f
# Escaping for special characters.
EQUALS = =
# The top-level source directory on which CMake was run.
CMAKE_SOURCE_DIR = /home/CHNOME/.local/share/deepin/uos-ai-assistant/workspaces/default/dock-lyrics-1.0.0
# The top-level build directory on which CMake was run.
CMAKE_BINARY_DIR = /home/CHNOME/.local/share/deepin/uos-ai-assistant/workspaces/default/dock-lyrics-1.0.0/build
# Targets provided globally by CMake.
# Special rule for the target edit_cache
edit_cache:
	@$(CMAKE_COMMAND) -E cmake_echo_color "--switch=$(COLOR)" --cyan "No interactive CMake dialog available..."
	/usr/bin/cmake -E echo No\ interactive\ CMake\ dialog\ available.
.PHONY : edit_cache
edit_cache/fast: edit_cache
.PHONY : edit_cache/fast
# Special rule for the target rebuild_cache
rebuild_cache:
	@$(CMAKE_COMMAND) -E cmake_echo_color "--switch=$(COLOR)" --cyan "Running CMake to regenerate build system..."
	/usr/bin/cmake --regenerate-during-build -S$(CMAKE_SOURCE_DIR) -B$(CMAKE_BINARY_DIR)
.PHONY : rebuild_cache
rebuild_cache/fast: rebuild_cache
.PHONY : rebuild_cache/fast
# Special rule for the target list_install_components
list_install_components:
	@$(CMAKE_COMMAND) -E cmake_echo_color "--switch=$(COLOR)" --cyan "Available install components are: \"Unspecified\""
.PHONY : list_install_components
list_install_components/fast: list_install_components
.PHONY : list_install_components/fast
# Special rule for the target install
install: preinstall
	@$(CMAKE_COMMAND) -E cmake_echo_color "--switch=$(COLOR)" --cyan "Install the project..."
	/usr/bin/cmake -P cmake_install.cmake
.PHONY : install
install/fast: preinstall/fast
.PHONY : install/fast
# Special rule for the target install/local
install/local: preinstall
	@$(CMAKE_COMMAND) -E cmake_echo_color "--switch=$(COLOR)" --cyan "Installing only the local directory..."
	/usr/bin/cmake -DCMAKE_INSTALL_LOCAL_ONLY=1 -P cmake_install.cmake
.PHONY : install/local
install/local/fast: preinstall/fast
.PHONY : install/local/fast
# Special rule for the target install/strip
install/strip: preinstall
	@$(CMAKE_COMMAND) -E cmake_echo_color "--switch=$(COLOR)" --cyan "Installing the project stripped..."
	/usr/bin/cmake -DCMAKE_INSTALL_DO_STRIP=1 -P cmake_install.cmake
.PHONY : install/strip
install/strip/fast: preinstall/fast
.PHONY : install/strip/fast
# The main all target
all: cmake_check_build_system
	$(CMAKE_COMMAND) -E cmake_progress_start /home/CHNOME/.local/share/deepin/uos-ai-assistant/workspaces/default/dock-lyrics-1.0.0/build/CMakeFiles /home/CHNOME/.local/share/deepin/uos-ai-assistant/workspaces/default/dock-lyrics-1.0.0/build//CMakeFiles/progress.marks
	$(MAKE) $(MAKESILENT) -f CMakeFiles/Makefile2 all
	$(CMAKE_COMMAND) -E cmake_progress_start /home/CHNOME/.local/share/deepin/uos-ai-assistant/workspaces/default/dock-lyrics-1.0.0/build/CMakeFiles 0
.PHONY : all
# The main clean target
clean:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/Makefile2 clean
.PHONY : clean
clean/fast: clean
.PHONY : clean/fast
# Prepare targets for installation.
preinstall: all
	$(MAKE) $(MAKESILENT) -f CMakeFiles/Makefile2 preinstall
.PHONY : preinstall
preinstall/fast:
.PHONY : preinstall/fast
# clear depends
depend:
	$(CMAKE_COMMAND) -S$(CMAKE_SOURCE_DIR) -B$(CMAKE_BINARY_DIR) --check-build-system CMakeFiles/Makefile.cmake 1
.PHONY : depend
# Target rules for targets named dock-lyrics
# Build rule for target.
dock-lyrics: cmake_check_build_system
	$(MAKE) $(MAKESILENT) -f CMakeFiles/Makefile2 dock-lyrics
.PHONY : dock-lyrics
# fast build rule for target.
dock-lyrics/fast:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/dock-lyrics.dir/build.make CMakeFiles/dock-lyrics.dir/build
.PHONY : dock-lyrics/fast
# Target rules for targets named org.deepin.ds.dock.lyrics_package
org.deepin.ds.dock.lyrics_package: cmake_check_build_system
	$(MAKE) $(MAKESILENT) -f CMakeFiles/Makefile2 org.deepin.ds.dock.lyrics_package
.PHONY : org.deepin.ds.dock.lyrics_package
org.deepin.ds.dock.lyrics_package/fast:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/org.deepin.ds.dock.lyrics_package.dir/build.make CMakeFiles/org.deepin.ds.dock.lyrics_package.dir/build
.PHONY : org.deepin.ds.dock.lyrics_package/fast
# Target rules for targets named dock-lyrics_autogen_timestamp_deps
dock-lyrics_autogen_timestamp_deps: cmake_check_build_system
	$(MAKE) $(MAKESILENT) -f CMakeFiles/Makefile2 dock-lyrics_autogen_timestamp_deps
.PHONY : dock-lyrics_autogen_timestamp_deps
dock-lyrics_autogen_timestamp_deps/fast:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/dock-lyrics_autogen_timestamp_deps.dir/build.make CMakeFiles/dock-lyrics_autogen_timestamp_deps.dir/build
.PHONY : dock-lyrics_autogen_timestamp_deps/fast
dock-lyrics_autogen: cmake_check_build_system
dock-lyrics_autogen/fast:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/dock-lyrics_autogen.dir/build.make CMakeFiles/dock-lyrics_autogen.dir/build
.PHONY : dock-lyrics_autogen/fast
dock-lyrics_autogen/mocs_compilation.o: dock-lyrics_autogen/mocs_compilation.cpp.o
.PHONY : dock-lyrics_autogen/mocs_compilation.o
# target to build an object file
dock-lyrics_autogen/mocs_compilation.cpp.o:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/dock-lyrics.dir/build.make CMakeFiles/dock-lyrics.dir/dock-lyrics_autogen/mocs_compilation.cpp.o
.PHONY : dock-lyrics_autogen/mocs_compilation.cpp.o
dock-lyrics_autogen/mocs_compilation.i: dock-lyrics_autogen/mocs_compilation.cpp.i
.PHONY : dock-lyrics_autogen/mocs_compilation.i
# target to preprocess a source file
dock-lyrics_autogen/mocs_compilation.cpp.i:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/dock-lyrics.dir/build.make CMakeFiles/dock-lyrics.dir/dock-lyrics_autogen/mocs_compilation.cpp.i
.PHONY : dock-lyrics_autogen/mocs_compilation.cpp.i
dock-lyrics_autogen/mocs_compilation.s: dock-lyrics_autogen/mocs_compilation.cpp.s
.PHONY : dock-lyrics_autogen/mocs_compilation.s
# target to generate assembly for a file
dock-lyrics_autogen/mocs_compilation.cpp.s:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/dock-lyrics.dir/build.make CMakeFiles/dock-lyrics.dir/dock-lyrics_autogen/mocs_compilation.cpp.s
.PHONY : dock-lyrics_autogen/mocs_compilation.cpp.s
src/lrcparser.o: src/lrcparser.cpp.o
.PHONY : src/lrcparser.o
src/lrcparser.cpp.o:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/dock-lyrics.dir/build.make CMakeFiles/dock-lyrics.dir/src/lrcparser.cpp.o
.PHONY : src/lrcparser.cpp.o
src/lrcparser.i: src/lrcparser.cpp.i
.PHONY : src/lrcparser.i
src/lrcparser.cpp.i:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/dock-lyrics.dir/build.make CMakeFiles/dock-lyrics.dir/src/lrcparser.cpp.i
.PHONY : src/lrcparser.cpp.i
src/lrcparser.s: src/lrcparser.cpp.s
.PHONY : src/lrcparser.s
src/lrcparser.cpp.s:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/dock-lyrics.dir/build.make CMakeFiles/dock-lyrics.dir/src/lrcparser.cpp.s
.PHONY : src/lrcparser.cpp.s
src/lyricsapplet.o: src/lyricsapplet.cpp.o
.PHONY : src/lyricsapplet.o
src/lyricsapplet.cpp.o:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/dock-lyrics.dir/build.make CMakeFiles/dock-lyrics.dir/src/lyricsapplet.cpp.o
.PHONY : src/lyricsapplet.cpp.o
src/lyricsapplet.i: src/lyricsapplet.cpp.i
.PHONY : src/lyricsapplet.i
src/lyricsapplet.cpp.i:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/dock-lyrics.dir/build.make CMakeFiles/dock-lyrics.dir/src/lyricsapplet.cpp.i
.PHONY : src/lyricsapplet.cpp.i
src/lyricsapplet.s: src/lyricsapplet.cpp.s
.PHONY : src/lyricsapplet.s
src/lyricsapplet.cpp.s:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/dock-lyrics.dir/build.make CMakeFiles/dock-lyrics.dir/src/lyricsapplet.cpp.s
.PHONY : src/lyricsapplet.cpp.s
src/lyricsfetcher.o: src/lyricsfetcher.cpp.o
.PHONY : src/lyricsfetcher.o
src/lyricsfetcher.cpp.o:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/dock-lyrics.dir/build.make CMakeFiles/dock-lyrics.dir/src/lyricsfetcher.cpp.o
.PHONY : src/lyricsfetcher.cpp.o
src/lyricsfetcher.i: src/lyricsfetcher.cpp.i
.PHONY : src/lyricsfetcher.i
src/lyricsfetcher.cpp.i:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/dock-lyrics.dir/build.make CMakeFiles/dock-lyrics.dir/src/lyricsfetcher.cpp.i
.PHONY : src/lyricsfetcher.cpp.i
src/lyricsfetcher.s: src/lyricsfetcher.cpp.s
.PHONY : src/lyricsfetcher.s
src/lyricsfetcher.cpp.s:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/dock-lyrics.dir/build.make CMakeFiles/dock-lyrics.dir/src/lyricsfetcher.cpp.s
.PHONY : src/lyricsfetcher.cpp.s
src/playerprobe.o: src/playerprobe.cpp.o
.PHONY : src/playerprobe.o
src/playerprobe.cpp.o:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/dock-lyrics.dir/build.make CMakeFiles/dock-lyrics.dir/src/playerprobe.cpp.o
.PHONY : src/playerprobe.cpp.o
src/playerprobe.i: src/playerprobe.cpp.i
.PHONY : src/playerprobe.i
src/playerprobe.cpp.i:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/dock-lyrics.dir/build.make CMakeFiles/dock-lyrics.dir/src/playerprobe.cpp.i
.PHONY : src/playerprobe.cpp.i
src/playerprobe.s: src/playerprobe.cpp.s
.PHONY : src/playerprobe.s
src/playerprobe.cpp.s:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/dock-lyrics.dir/build.make CMakeFiles/dock-lyrics.dir/src/playerprobe.cpp.s
.PHONY : src/playerprobe.cpp.s
# Help Target
help:
	@echo "The following are some of the valid targets for this Makefile:"
	@echo "... all (the default if no target is provided)"
	@echo "... clean"
	@echo "... depend"
	@echo "... edit_cache"
	@echo "... install"
	@echo "... install/local"
	@echo "... install/strip"
	@echo "... list_install_components"
	@echo "... rebuild_cache"
	@echo "... dock-lyrics_autogen"
	@echo "... dock-lyrics_autogen_timestamp_deps"
	@echo "... org.deepin.ds.dock.lyrics_package"
	@echo "... dock-lyrics"
	@echo "... dock-lyrics_autogen/mocs_compilation.o"
	@echo "... dock-lyrics_autogen/mocs_compilation.i"
	@echo "... dock-lyrics_autogen/mocs_compilation.s"
	@echo "... src/lrcparser.o"
	@echo "... src/lrcparser.i"
	@echo "... src/lrcparser.s"
	@echo "... src/lyricsapplet.o"
	@echo "... src/lyricsapplet.i"
	@echo "... src/lyricsapplet.s"
	@echo "... src/lyricsfetcher.o"
	@echo "... src/lyricsfetcher.i"
	@echo "... src/lyricsfetcher.s"
	@echo "... src/playerprobe.o"
	@echo "... src/playerprobe.i"
	@echo "... src/playerprobe.s"
.PHONY : help
# Special targets to cleanup operation of make.
# Special rule to run CMake to check the build system integrity.
# No rule that depends on this can have commands that come from listfiles
# because they might be regenerated.
cmake_check_build_system:
	$(CMAKE_COMMAND) -S$(CMAKE_SOURCE_DIR) -B$(CMAKE_BINARY_DIR) --check-build-system CMakeFiles/Makefile.cmake 0
.PHONY : cmake_check_build_system
