# CMAKE generated file: DO NOT EDIT!
# Generated by "Unix Makefiles" Generator, CMake Version 3.31
# Default target executed when no arguments are given to make.
default_target: all
.PHONY : default_target
# Allow only one "make -f Makefile2" at a time, but pass parallelism.
.NOTPARALLEL:
# Special targets provided by cmake.
# Disable implicit rules so canonical targets will work.
.SUFFIXES:
# Disable VCS-based implicit rules.
% : %,v
% : RCS/%
% : RCS/%,v
% : SCCS/s.%
% : s.%
.SUFFIXES: .hpux_make_needs_suffix_list
# Command-line flag to silence nested $(MAKE).
$(VERBOSE)MAKESILENT = -s
#Suppress display of executed commands.
$(VERBOSE).SILENT:
# A target that is always out of date.
cmake_force:
.PHONY : cmake_force
# Set environment variables for the build.
# The shell in which to execute make rules.
SHELL = /bin/sh
# The CMake executable.
CMAKE_COMMAND = /usr/bin/cmake
# The command to remove a file.
RM = /usr/bin/cmake -E rm -f
# Escaping for special characters.
EQUALS = =
# The top-level source directory on which CMake was run.
CMAKE_SOURCE_DIR = /home/Wind/Documents/软件开发/蓝牙电量插件/dde-bt-battery-tray
# The top-level build directory on which CMake was run.
CMAKE_BINARY_DIR = /home/Wind/Documents/软件开发/蓝牙电量插件/dde-bt-battery-tray/build
# Targets provided globally by CMake.
# Special rule for the target edit_cache
edit_cache:
	@$(CMAKE_COMMAND) -E cmake_echo_color "--switch=$(COLOR)" --cyan "No interactive CMake dialog available..."
	/usr/bin/cmake -E echo No\ interactive\ CMake\ dialog\ available.
.PHONY : edit_cache
edit_cache/fast: edit_cache
.PHONY : edit_cache/fast
# Special rule for the target rebuild_cache
rebuild_cache:
	@$(CMAKE_COMMAND) -E cmake_echo_color "--switch=$(COLOR)" --cyan "Running CMake to regenerate build system..."
	/usr/bin/cmake --regenerate-during-build -S$(CMAKE_SOURCE_DIR) -B$(CMAKE_BINARY_DIR)
.PHONY : rebuild_cache
rebuild_cache/fast: rebuild_cache
.PHONY : rebuild_cache/fast
# Special rule for the target list_install_components
list_install_components:
	@$(CMAKE_COMMAND) -E cmake_echo_color "--switch=$(COLOR)" --cyan "Available install components are: \"Unspecified\""
.PHONY : list_install_components
list_install_components/fast: list_install_components
.PHONY : list_install_components/fast
# Special rule for the target install
install: preinstall
	@$(CMAKE_COMMAND) -E cmake_echo_color "--switch=$(COLOR)" --cyan "Install the project..."
	/usr/bin/cmake -P cmake_install.cmake
.PHONY : install
install/fast: preinstall/fast
.PHONY : install/fast
# Special rule for the target install/local
install/local: preinstall
	@$(CMAKE_COMMAND) -E cmake_echo_color "--switch=$(COLOR)" --cyan "Installing only the local directory..."
	/usr/bin/cmake -DCMAKE_INSTALL_LOCAL_ONLY=1 -P cmake_install.cmake
.PHONY : install/local
install/local/fast: preinstall/fast
.PHONY : install/local/fast
# Special rule for the target install/strip
install/strip: preinstall
	@$(CMAKE_COMMAND) -E cmake_echo_color "--switch=$(COLOR)" --cyan "Installing the project stripped..."
	/usr/bin/cmake -DCMAKE_INSTALL_DO_STRIP=1 -P cmake_install.cmake
.PHONY : install/strip
install/strip/fast: preinstall/fast
.PHONY : install/strip/fast
# The main all target
all: cmake_check_build_system
	$(CMAKE_COMMAND) -E cmake_progress_start /home/Wind/Documents/软件开发/蓝牙电量插件/dde-bt-battery-tray/build/CMakeFiles /home/Wind/Documents/软件开发/蓝牙电量插件/dde-bt-battery-tray/build//CMakeFiles/progress.marks
	$(MAKE) $(MAKESILENT) -f CMakeFiles/Makefile2 all
	$(CMAKE_COMMAND) -E cmake_progress_start /home/Wind/Documents/软件开发/蓝牙电量插件/dde-bt-battery-tray/build/CMakeFiles 0
.PHONY : all
# The main clean target
clean:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/Makefile2 clean
.PHONY : clean
clean/fast: clean
.PHONY : clean/fast
# Prepare targets for installation.
preinstall: all
	$(MAKE) $(MAKESILENT) -f CMakeFiles/Makefile2 preinstall
.PHONY : preinstall
preinstall/fast:
.PHONY : preinstall/fast
# clear depends
depend:
	$(CMAKE_COMMAND) -S$(CMAKE_SOURCE_DIR) -B$(CMAKE_BINARY_DIR) --check-build-system CMakeFiles/Makefile.cmake 1
.PHONY : depend
# Target rules for targets named bt-battery-tray
# Build rule for target.
bt-battery-tray: cmake_check_build_system
	$(MAKE) $(MAKESILENT) -f CMakeFiles/Makefile2 bt-battery-tray
.PHONY : bt-battery-tray
# fast build rule for target.
bt-battery-tray/fast:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/bt-battery-tray.dir/build.make CMakeFiles/bt-battery-tray.dir/build
.PHONY : bt-battery-tray/fast
# Target rules for targets named bt-battery-tray_autogen_timestamp_deps
bt-battery-tray_autogen_timestamp_deps: cmake_check_build_system
	$(MAKE) $(MAKESILENT) -f CMakeFiles/Makefile2 bt-battery-tray_autogen_timestamp_deps
.PHONY : bt-battery-tray_autogen_timestamp_deps
bt-battery-tray_autogen_timestamp_deps/fast:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/bt-battery-tray_autogen_timestamp_deps.dir/build.make CMakeFiles/bt-battery-tray_autogen_timestamp_deps.dir/build
.PHONY : bt-battery-tray_autogen_timestamp_deps/fast
bt-battery-tray_autogen: cmake_check_build_system
bt-battery-tray_autogen/fast:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/bt-battery-tray_autogen.dir/build.make CMakeFiles/bt-battery-tray_autogen.dir/build
.PHONY : bt-battery-tray_autogen/fast
bt-battery-tray_autogen/EWIEGA46WW/qrc_resources.o: bt-battery-tray_autogen/EWIEGA46WW/qrc_resources.cpp.o
.PHONY : bt-battery-tray_autogen/EWIEGA46WW/qrc_resources.o
# target to build an object file
bt-battery-tray_autogen/EWIEGA46WW/qrc_resources.cpp.o:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/bt-battery-tray.dir/build.make CMakeFiles/bt-battery-tray.dir/bt-battery-tray_autogen/EWIEGA46WW/qrc_resources.cpp.o
.PHONY : bt-battery-tray_autogen/EWIEGA46WW/qrc_resources.cpp.o
bt-battery-tray_autogen/EWIEGA46WW/qrc_resources.i: bt-battery-tray_autogen/EWIEGA46WW/qrc_resources.cpp.i
.PHONY : bt-battery-tray_autogen/EWIEGA46WW/qrc_resources.i
# target to preprocess a source file
bt-battery-tray_autogen/EWIEGA46WW/qrc_resources.cpp.i:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/bt-battery-tray.dir/build.make CMakeFiles/bt-battery-tray.dir/bt-battery-tray_autogen/EWIEGA46WW/qrc_resources.cpp.i
.PHONY : bt-battery-tray_autogen/EWIEGA46WW/qrc_resources.cpp.i
bt-battery-tray_autogen/EWIEGA46WW/qrc_resources.s: bt-battery-tray_autogen/EWIEGA46WW/qrc_resources.cpp.s
.PHONY : bt-battery-tray_autogen/EWIEGA46WW/qrc_resources.s
# target to generate assembly for a file
bt-battery-tray_autogen/EWIEGA46WW/qrc_resources.cpp.s:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/bt-battery-tray.dir/build.make CMakeFiles/bt-battery-tray.dir/bt-battery-tray_autogen/EWIEGA46WW/qrc_resources.cpp.s
.PHONY : bt-battery-tray_autogen/EWIEGA46WW/qrc_resources.cpp.s
bt-battery-tray_autogen/mocs_compilation.o: bt-battery-tray_autogen/mocs_compilation.cpp.o
.PHONY : bt-battery-tray_autogen/mocs_compilation.o
bt-battery-tray_autogen/mocs_compilation.cpp.o:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/bt-battery-tray.dir/build.make CMakeFiles/bt-battery-tray.dir/bt-battery-tray_autogen/mocs_compilation.cpp.o
.PHONY : bt-battery-tray_autogen/mocs_compilation.cpp.o
bt-battery-tray_autogen/mocs_compilation.i: bt-battery-tray_autogen/mocs_compilation.cpp.i
.PHONY : bt-battery-tray_autogen/mocs_compilation.i
bt-battery-tray_autogen/mocs_compilation.cpp.i:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/bt-battery-tray.dir/build.make CMakeFiles/bt-battery-tray.dir/bt-battery-tray_autogen/mocs_compilation.cpp.i
.PHONY : bt-battery-tray_autogen/mocs_compilation.cpp.i
bt-battery-tray_autogen/mocs_compilation.s: bt-battery-tray_autogen/mocs_compilation.cpp.s
.PHONY : bt-battery-tray_autogen/mocs_compilation.s
bt-battery-tray_autogen/mocs_compilation.cpp.s:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/bt-battery-tray.dir/build.make CMakeFiles/bt-battery-tray.dir/bt-battery-tray_autogen/mocs_compilation.cpp.s
.PHONY : bt-battery-tray_autogen/mocs_compilation.cpp.s
btbatterymonitor.o: btbatterymonitor.cpp.o
.PHONY : btbatterymonitor.o
btbatterymonitor.cpp.o:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/bt-battery-tray.dir/build.make CMakeFiles/bt-battery-tray.dir/btbatterymonitor.cpp.o
.PHONY : btbatterymonitor.cpp.o
btbatterymonitor.i: btbatterymonitor.cpp.i
.PHONY : btbatterymonitor.i
btbatterymonitor.cpp.i:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/bt-battery-tray.dir/build.make CMakeFiles/bt-battery-tray.dir/btbatterymonitor.cpp.i
.PHONY : btbatterymonitor.cpp.i
btbatterymonitor.s: btbatterymonitor.cpp.s
.PHONY : btbatterymonitor.s
btbatterymonitor.cpp.s:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/bt-battery-tray.dir/build.make CMakeFiles/bt-battery-tray.dir/btbatterymonitor.cpp.s
.PHONY : btbatterymonitor.cpp.s
btbatterytrayplugin.o: btbatterytrayplugin.cpp.o
.PHONY : btbatterytrayplugin.o
btbatterytrayplugin.cpp.o:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/bt-battery-tray.dir/build.make CMakeFiles/bt-battery-tray.dir/btbatterytrayplugin.cpp.o
.PHONY : btbatterytrayplugin.cpp.o
btbatterytrayplugin.i: btbatterytrayplugin.cpp.i
.PHONY : btbatterytrayplugin.i
btbatterytrayplugin.cpp.i:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/bt-battery-tray.dir/build.make CMakeFiles/bt-battery-tray.dir/btbatterytrayplugin.cpp.i
.PHONY : btbatterytrayplugin.cpp.i
btbatterytrayplugin.s: btbatterytrayplugin.cpp.s
.PHONY : btbatterytrayplugin.s
btbatterytrayplugin.cpp.s:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/bt-battery-tray.dir/build.make CMakeFiles/bt-battery-tray.dir/btbatterytrayplugin.cpp.s
.PHONY : btbatterytrayplugin.cpp.s
btbatterywidget.o: btbatterywidget.cpp.o
.PHONY : btbatterywidget.o
btbatterywidget.cpp.o:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/bt-battery-tray.dir/build.make CMakeFiles/bt-battery-tray.dir/btbatterywidget.cpp.o
.PHONY : btbatterywidget.cpp.o
btbatterywidget.i: btbatterywidget.cpp.i
.PHONY : btbatterywidget.i
btbatterywidget.cpp.i:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/bt-battery-tray.dir/build.make CMakeFiles/bt-battery-tray.dir/btbatterywidget.cpp.i
.PHONY : btbatterywidget.cpp.i
btbatterywidget.s: btbatterywidget.cpp.s
.PHONY : btbatterywidget.s
btbatterywidget.cpp.s:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/bt-battery-tray.dir/build.make CMakeFiles/bt-battery-tray.dir/btbatterywidget.cpp.s
.PHONY : btbatterywidget.cpp.s
# Help Target
help:
	@echo "The following are some of the valid targets for this Makefile:"
	@echo "... all (the default if no target is provided)"
	@echo "... clean"
	@echo "... depend"
	@echo "... edit_cache"
	@echo "... install"
	@echo "... install/local"
	@echo "... install/strip"
	@echo "... list_install_components"
	@echo "... rebuild_cache"
	@echo "... bt-battery-tray_autogen"
	@echo "... bt-battery-tray_autogen_timestamp_deps"
	@echo "... bt-battery-tray"
	@echo "... bt-battery-tray_autogen/EWIEGA46WW/qrc_resources.o"
	@echo "... bt-battery-tray_autogen/EWIEGA46WW/qrc_resources.i"
	@echo "... bt-battery-tray_autogen/EWIEGA46WW/qrc_resources.s"
	@echo "... bt-battery-tray_autogen/mocs_compilation.o"
	@echo "... bt-battery-tray_autogen/mocs_compilation.i"
	@echo "... bt-battery-tray_autogen/mocs_compilation.s"
	@echo "... btbatterymonitor.o"
	@echo "... btbatterymonitor.i"
	@echo "... btbatterymonitor.s"
	@echo "... btbatterytrayplugin.o"
	@echo "... btbatterytrayplugin.i"
	@echo "... btbatterytrayplugin.s"
	@echo "... btbatterywidget.o"
	@echo "... btbatterywidget.i"
	@echo "... btbatterywidget.s"
.PHONY : help
# Special targets to cleanup operation of make.
# Special rule to run CMake to check the build system integrity.
# No rule that depends on this can have commands that come from listfiles
# because they might be regenerated.
cmake_check_build_system:
	$(CMAKE_COMMAND) -S$(CMAKE_SOURCE_DIR) -B$(CMAKE_BINARY_DIR) --check-build-system CMakeFiles/Makefile.cmake 0
.PHONY : cmake_check_build_system
