# Makefile for building: samp15_3
# Generated by qmake (3.1) (Qt 5.15.8)
# Project:  samp15_3.pro
# Template: app
# Command: /usr/lib/qt5/bin/qmake -o Makefile samp15_3.pro -spec linux-g++ CONFIG+=debug CONFIG+=qml_debug
MAKEFILE      = Makefile
EQ            = =
####### Compiler, tools and options
CC            = gcc
CXX           = g++
DEFINES       = -DQT_QML_DEBUG -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_CORE_LIB
CFLAGS        = -pipe -g -Wall -Wextra -D_REENTRANT -fPIC $(DEFINES)
CXXFLAGS      = -pipe -g -std=gnu++11 -Wall -Wextra -D_REENTRANT -fPIC $(DEFINES)
INCPATH       = -I. -I/usr/include/x86_64-linux-gnu/qt5 -I/usr/include/x86_64-linux-gnu/qt5/QtWidgets -I/usr/include/x86_64-linux-gnu/qt5/QtGui -I/usr/include/x86_64-linux-gnu/qt5/QtNetwork -I/usr/include/x86_64-linux-gnu/qt5/QtCore -I. -I. -I/usr/lib/x86_64-linux-gnu/qt5/mkspecs/linux-g++
QMAKE         = /usr/lib/qt5/bin/qmake
DEL_FILE      = rm -f
CHK_DIR_EXISTS= test -d
MKDIR         = mkdir -p
COPY          = cp -f
COPY_FILE     = cp -f
COPY_DIR      = cp -f -R
INSTALL_FILE  = install -m 644 -p
INSTALL_PROGRAM = install -m 755 -p
INSTALL_DIR   = cp -f -R
QINSTALL      = /usr/lib/qt5/bin/qmake -install qinstall
QINSTALL_PROGRAM = /usr/lib/qt5/bin/qmake -install qinstall -exe
DEL_FILE      = rm -f
SYMLINK       = ln -f -s
DEL_DIR       = rmdir
MOVE          = mv -f
TAR           = tar -cf
COMPRESS      = gzip -9f
DISTNAME      = samp15_31.0.0
DISTDIR = /media/deepin/datessd/qt/《Qt\ 6\ C++开发指南》全书示例源码、演示软件及使用说明/《Qt\ 6\ C++开发指南》全书示例源码、演示软件及使用说明/02《Qt\ 6\ C++开发指南》全书示例源码--qmake完整版\ V1.1（与书内容对应）/Chap15_Network/samp15_3UDP/.tmp/samp15_31.0.0
LINK          = g++
LFLAGS        =
LIBS          = $(SUBLIBS) /usr/lib/x86_64-linux-gnu/libQt5Widgets.so /usr/lib/x86_64-linux-gnu/libQt5Gui.so /usr/lib/x86_64-linux-gnu/libQt5Network.so /usr/lib/x86_64-linux-gnu/libQt5Core.so -lGL -lpthread
AR            = ar cqs
RANLIB        =
SED           = sed
STRIP         = strip
####### Output directory
OBJECTS_DIR   = ./
####### Files
SOURCES       = main.cpp \
		mainwindow.cpp qrc_res.cpp \
		moc_mainwindow.cpp
OBJECTS       = main.o \
		mainwindow.o \
		qrc_res.o \
		moc_mainwindow.o
DIST          = /usr/lib/x86_64-linux-gnu/qt5/mkspecs/features/spec_pre.prf \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/common/unix.conf \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/common/linux.conf \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/common/sanitize.conf \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/common/gcc-base.conf \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/common/gcc-base-unix.conf \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/common/g++-base.conf \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/common/g++-unix.conf \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/qconfig.pri \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_accessibility_support_private.pri \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_bootstrap_private.pri \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_concurrent.pri \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_concurrent_private.pri \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_core.pri \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_core_private.pri \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_dbus.pri \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_dbus_private.pri \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_devicediscovery_support_private.pri \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_edid_support_private.pri \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_egl_support_private.pri \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_eglfs_kms_support_private.pri \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_eglfsdeviceintegration_private.pri \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_eventdispatcher_support_private.pri \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_fb_support_private.pri \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_fontdatabase_support_private.pri \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_glx_support_private.pri \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_gui.pri \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_gui_private.pri \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_input_support_private.pri \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_kms_support_private.pri \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_linuxaccessibility_support_private.pri \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_network.pri \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_network_private.pri \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_opengl.pri \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_opengl_private.pri \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_openglextensions.pri \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_openglextensions_private.pri \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_platformcompositor_support_private.pri \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_printsupport.pri \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_printsupport_private.pri \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_service_support_private.pri \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_sql.pri \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_sql_private.pri \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_testlib.pri \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_testlib_private.pri \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_theme_support_private.pri \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_vulkan_support_private.pri \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_widgets.pri \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_widgets_private.pri \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_xcb_qpa_lib_private.pri \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_xkbcommon_support_private.pri \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_xml.pri \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_xml_private.pri \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/features/qt_functions.prf \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/features/qt_config.prf \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/linux-g++/qmake.conf \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/features/spec_post.prf \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/features/exclusive_builds.prf \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/features/toolchain.prf \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/features/default_pre.prf \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/features/resolve_config.prf \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/features/default_post.prf \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/features/qml_debug.prf \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/features/warn_on.prf \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/features/qt.prf \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/features/resources_functions.prf \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/features/resources.prf \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/features/moc.prf \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/features/unix/opengl.prf \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/features/uic.prf \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/features/unix/thread.prf \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/features/qmake_use.prf \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/features/file_copies.prf \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/features/testcase_targets.prf \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/features/exceptions.prf \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/features/yacc.prf \
		/usr/lib/x86_64-linux-gnu/qt5/mkspecs/features/lex.prf \
		samp15_3.pro mainwindow.h main.cpp \
		mainwindow.cpp
QMAKE_TARGET  = samp15_3
DESTDIR       =
TARGET        = samp15_3
first: all
####### Build rules
samp15_3: ui_mainwindow.h $(OBJECTS)
	$(LINK) $(LFLAGS) -o $(TARGET) $(OBJECTS) $(OBJCOMP) $(LIBS)
Makefile: samp15_3.pro /usr/lib/x86_64-linux-gnu/qt5/mkspecs/linux-g++/qmake.conf /usr/lib/x86_64-linux-gnu/qt5/mkspecs/features/spec_pre.prf \
		samp15_3.pro \
		res.qrc
	$(QMAKE) -o Makefile samp15_3.pro -spec linux-g++ CONFIG+=debug CONFIG+=qml_debug
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/features/spec_pre.prf:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/common/unix.conf:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/common/linux.conf:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/common/sanitize.conf:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/common/gcc-base.conf:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/common/gcc-base-unix.conf:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/common/g++-base.conf:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/common/g++-unix.conf:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/qconfig.pri:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_accessibility_support_private.pri:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_bootstrap_private.pri:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_concurrent.pri:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_concurrent_private.pri:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_core.pri:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_core_private.pri:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_dbus.pri:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_dbus_private.pri:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_devicediscovery_support_private.pri:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_edid_support_private.pri:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_egl_support_private.pri:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_eglfs_kms_support_private.pri:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_eglfsdeviceintegration_private.pri:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_eventdispatcher_support_private.pri:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_fb_support_private.pri:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_fontdatabase_support_private.pri:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_glx_support_private.pri:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_gui.pri:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_gui_private.pri:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_input_support_private.pri:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_kms_support_private.pri:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_linuxaccessibility_support_private.pri:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_network.pri:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_network_private.pri:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_opengl.pri:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_opengl_private.pri:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_openglextensions.pri:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_openglextensions_private.pri:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_platformcompositor_support_private.pri:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_printsupport.pri:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_printsupport_private.pri:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_service_support_private.pri:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_sql.pri:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_sql_private.pri:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_testlib.pri:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_testlib_private.pri:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_theme_support_private.pri:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_vulkan_support_private.pri:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_widgets.pri:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_widgets_private.pri:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_xcb_qpa_lib_private.pri:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_xkbcommon_support_private.pri:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_xml.pri:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/modules/qt_lib_xml_private.pri:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/features/qt_functions.prf:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/features/qt_config.prf:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/linux-g++/qmake.conf:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/features/spec_post.prf:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/features/exclusive_builds.prf:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/features/toolchain.prf:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/features/default_pre.prf:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/features/resolve_config.prf:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/features/default_post.prf:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/features/qml_debug.prf:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/features/warn_on.prf:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/features/qt.prf:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/features/resources_functions.prf:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/features/resources.prf:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/features/moc.prf:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/features/unix/opengl.prf:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/features/uic.prf:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/features/unix/thread.prf:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/features/qmake_use.prf:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/features/file_copies.prf:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/features/testcase_targets.prf:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/features/exceptions.prf:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/features/yacc.prf:
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/features/lex.prf:
samp15_3.pro:
res.qrc:
qmake: FORCE
	@$(QMAKE) -o Makefile samp15_3.pro -spec linux-g++ CONFIG+=debug CONFIG+=qml_debug
qmake_all: FORCE
all: Makefile samp15_3
dist: distdir FORCE
	(cd `dirname $(DISTDIR)` && $(TAR) $(DISTNAME).tar $(DISTNAME) && $(COMPRESS) $(DISTNAME).tar) && $(MOVE) `dirname $(DISTDIR)`/$(DISTNAME).tar.gz . && $(DEL_FILE) -r $(DISTDIR)
distdir: FORCE
	@test -d $(DISTDIR) || mkdir -p $(DISTDIR)
	$(COPY_FILE) --parents $(DIST) $(DISTDIR)/
	$(COPY_FILE) --parents res.qrc $(DISTDIR)/
	$(COPY_FILE) --parents /usr/lib/x86_64-linux-gnu/qt5/mkspecs/features/data/dummy.cpp $(DISTDIR)/
	$(COPY_FILE) --parents mainwindow.h $(DISTDIR)/
	$(COPY_FILE) --parents main.cpp mainwindow.cpp $(DISTDIR)/
	$(COPY_FILE) --parents mainwindow.ui $(DISTDIR)/
clean: compiler_clean
	-$(DEL_FILE) $(OBJECTS)
	-$(DEL_FILE) *~ core *.core
distclean: clean
	-$(DEL_FILE) $(TARGET)
	-$(DEL_FILE) .qmake.stash
	-$(DEL_FILE) Makefile
####### Sub-libraries
mocclean: compiler_moc_header_clean compiler_moc_objc_header_clean compiler_moc_source_clean
mocables: compiler_moc_header_make_all compiler_moc_objc_header_make_all compiler_moc_source_make_all
check: first
benchmark: first
compiler_rcc_make_all: qrc_res.cpp
compiler_rcc_clean:
	-$(DEL_FILE) qrc_res.cpp
qrc_res.cpp: res.qrc \
		/usr/lib/qt5/bin/rcc \
		images/132.bmp \
		images/110.JPG \
		images/620.bmp \
		images/624.bmp \
		images/212.bmp
	/usr/lib/qt5/bin/rcc -name res res.qrc -o qrc_res.cpp
compiler_moc_predefs_make_all: moc_predefs.h
compiler_moc_predefs_clean:
	-$(DEL_FILE) moc_predefs.h
moc_predefs.h: /usr/lib/x86_64-linux-gnu/qt5/mkspecs/features/data/dummy.cpp
	g++ -pipe -g -std=gnu++11 -Wall -Wextra -dM -E -o moc_predefs.h /usr/lib/x86_64-linux-gnu/qt5/mkspecs/features/data/dummy.cpp
compiler_moc_header_make_all: moc_mainwindow.cpp
compiler_moc_header_clean:
	-$(DEL_FILE) moc_mainwindow.cpp
moc_mainwindow.cpp: mainwindow.h \
		moc_predefs.h \
		/usr/lib/qt5/bin/moc
	/usr/lib/qt5/bin/moc $(DEFINES) --include '/media/deepin/datessd/qt/《Qt 6 C++开发指南》全书示例源码、演示软件及使用说明/《Qt 6 C++开发指南》全书示例源码、演示软件及使用说明/02《Qt 6 C++开发指南》全书示例源码--qmake完整版 V1.1（与书内容对应）/Chap15_Network/samp15_3UDP/moc_predefs.h' -I/usr/lib/x86_64-linux-gnu/qt5/mkspecs/linux-g++ -I'/media/deepin/datessd/qt/《Qt 6 C++开发指南》全书示例源码、演示软件及使用说明/《Qt 6 C++开发指南》全书示例源码、演示软件及使用说明/02《Qt 6 C++开发指南》全书示例源码--qmake完整版 V1.1（与书内容对应）/Chap15_Network/samp15_3UDP' -I/usr/include/x86_64-linux-gnu/qt5 -I/usr/include/x86_64-linux-gnu/qt5/QtWidgets -I/usr/include/x86_64-linux-gnu/qt5/QtGui -I/usr/include/x86_64-linux-gnu/qt5/QtNetwork -I/usr/include/x86_64-linux-gnu/qt5/QtCore -I/usr/include/c++/8 -I/usr/include/x86_64-linux-gnu/c++/8 -I/usr/include/c++/8/backward -I/usr/lib/gcc/x86_64-linux-gnu/8/include -I/usr/local/include -I/usr/lib/gcc/x86_64-linux-gnu/8/include-fixed -I/usr/include/x86_64-linux-gnu -I/usr/include mainwindow.h -o moc_mainwindow.cpp
compiler_moc_objc_header_make_all:
compiler_moc_objc_header_clean:
compiler_moc_source_make_all:
compiler_moc_source_clean:
compiler_uic_make_all: ui_mainwindow.h
compiler_uic_clean:
	-$(DEL_FILE) ui_mainwindow.h
ui_mainwindow.h: mainwindow.ui \
		/usr/lib/qt5/bin/uic
	/usr/lib/qt5/bin/uic mainwindow.ui -o ui_mainwindow.h
compiler_yacc_decl_make_all:
compiler_yacc_decl_clean:
compiler_yacc_impl_make_all:
compiler_yacc_impl_clean:
compiler_lex_make_all:
compiler_lex_clean:
compiler_clean: compiler_rcc_clean compiler_moc_predefs_clean compiler_moc_header_clean compiler_uic_clean
####### Compile
main.o: main.cpp mainwindow.h
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o main.o main.cpp
mainwindow.o: mainwindow.cpp mainwindow.h \
		ui_mainwindow.h
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o mainwindow.o mainwindow.cpp
qrc_res.o: qrc_res.cpp
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o qrc_res.o qrc_res.cpp
moc_mainwindow.o: moc_mainwindow.cpp
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o moc_mainwindow.o moc_mainwindow.cpp
####### Install
install_target: first FORCE
	@test -d $(INSTALL_ROOT)/opt/samp15_3/bin || mkdir -p $(INSTALL_ROOT)/opt/samp15_3/bin
	$(QINSTALL_PROGRAM) $(QMAKE_TARGET) $(INSTALL_ROOT)/opt/samp15_3/bin/$(QMAKE_TARGET)
uninstall_target: FORCE
	-$(DEL_FILE) $(INSTALL_ROOT)/opt/samp15_3/bin/$(QMAKE_TARGET)
	-$(DEL_DIR) $(INSTALL_ROOT)/opt/samp15_3/bin/
install: install_target  FORCE
uninstall: uninstall_target  FORCE
FORCE:
