EXTRA_CFLAGS += $(USER_EXTRA_CFLAGS)
EXTRA_CFLAGS += -O2
EXTRA_CFLAGS += -Wall
EXTRA_CFLAGS += -Wextra
#EXTRA_CFLAGS += -pedantic
#EXTRA_CFLAGS += -Wshadow -Wpointer-arith -Wcast-qual -Wstrict-prototypes -Wmissing-prototypes
EXTRA_CFLAGS += -Wno-cast-function-type
EXTRA_CFLAGS += -Wno-type-limits
EXTRA_CFLAGS += -Wno-unused-function
EXTRA_CFLAGS += -Wno-unused-parameter
EXTRA_CFLAGS += -Wno-unused-variable
EXTRA_CFLAGS += -Wno-array-bounds
GCC_VER_49 := $(shell echo `$(CC) -dumpversion | cut -f1-2 -d.` \>= 4.9 | bc )
ifeq ($(GCC_VER_49),1)
EXTRA_CFLAGS += -Wno-date-time	# Fix compile error && warning on gcc 4.9 and later
endif
EXTRA_CFLAGS += -I$(src)/include
EXTRA_LDFLAGS += --strip-debug
CONFIG_AUTOCFG_CP = n
########################## WIFI IC ############################
CONFIG_MULTIDRV = n
CONFIG_RTL8188E = n
CONFIG_RTL8812A = n
CONFIG_RTL8821A = n
CONFIG_RTL8192E = n
CONFIG_RTL8723B = n
CONFIG_RTL8814A = n
CONFIG_RTL8723C = n
CONFIG_RTL8188F = n
CONFIG_RTL8188GTV = n
CONFIG_RTL8822B = y
CONFIG_RTL8723D = n
CONFIG_RTL8821C = n
CONFIG_RTL8710B = n
CONFIG_RTL8192F = n
CONFIG_RTL8822C = n
CONFIG_RTL8814B = n
######################### Interface ###########################
CONFIG_USB_HCI = y
CONFIG_PCI_HCI = n
CONFIG_SDIO_HCI = n
CONFIG_GSPI_HCI = n
########################## Features ###########################
CONFIG_NET_NS=y
CONFIG_MP_INCLUDED = y
CONFIG_POWER_SAVING = y
CONFIG_IPS_MODE = default
CONFIG_LPS_MODE = default
CONFIG_USB_AUTOSUSPEND = n
CONFIG_HW_PWRP_DETECTION = n
CONFIG_BT_COEXIST = y
CONFIG_WAPI_SUPPORT = n
CONFIG_EFUSE_CONFIG_FILE = y
CONFIG_EXT_CLK = n
CONFIG_TRAFFIC_PROTECT = n
CONFIG_LOAD_PHY_PARA_FROM_FILE = y
CONFIG_TXPWR_BY_RATE = y
CONFIG_TXPWR_BY_RATE_EN = y
CONFIG_TXPWR_LIMIT = y
CONFIG_TXPWR_LIMIT_EN = n
CONFIG_RTW_CHPLAN = 0xFF
CONFIG_RTW_ADAPTIVITY_EN = disable
CONFIG_RTW_ADAPTIVITY_MODE = normal
CONFIG_SIGNAL_SCALE_MAPPING = n
CONFIG_80211W = y
CONFIG_REDUCE_TX_CPU_LOADING = n
CONFIG_BR_EXT = y
CONFIG_TDLS = n
CONFIG_WIFI_MONITOR = n
CONFIG_MCC_MODE = n
CONFIG_APPEND_VENDOR_IE_ENABLE = n
CONFIG_RTW_NAPI = y
CONFIG_RTW_GRO = y
CONFIG_RTW_NETIF_SG = y
CONFIG_RTW_IPCAM_APPLICATION = n
CONFIG_RTW_REPEATER_SON = n
CONFIG_RTW_WIFI_HAL = n
CONFIG_ICMP_VOQ = n
CONFIG_IP_R_MONITOR = n #arp VOQ and high rate
# user priority mapping rule : tos, dscp
CONFIG_RTW_UP_MAPPING_RULE = tos
# Enable VHT rate on 2.4G channel or not
CONFIG_RTW_VHT_2G4 = y
########################## Debug ###########################
CONFIG_RTW_DEBUG = n
# default log level is _DRV_INFO_ = 4,
# please refer to "How_to_set_driver_debug_log_level.doc" to set the available level.
CONFIG_RTW_LOG_LEVEL = 2
# enable /proc/net/rtlxxxx/ debug interfaces
CONFIG_PROC_DEBUG = y
######################## Wake On Lan ##########################
CONFIG_WOWLAN = n
#bit2: deauth, bit1: unicast, bit0: magic pkt.
CONFIG_WAKEUP_TYPE = 0x7
CONFIG_WOW_LPS_MODE = default
#bit0: disBBRF off, #bit1: Wireless remote controller (WRC)
CONFIG_SUSPEND_TYPE = 0
CONFIG_WOW_STA_MIX = n
CONFIG_GPIO_WAKEUP = n
CONFIG_WAKEUP_GPIO_IDX = default
CONFIG_HIGH_ACTIVE_DEV2HST = n
######### only for USB #########
CONFIG_ONE_PIN_GPIO = n
CONFIG_HIGH_ACTIVE_HST2DEV = n
CONFIG_PNO_SUPPORT = n
CONFIG_PNO_SET_DEBUG = n
CONFIG_AP_WOWLAN = n
######### Notify SDIO Host Keep Power During Syspend ##########
CONFIG_RTW_SDIO_PM_KEEP_POWER = y
###################### MP HW TX MODE FOR VHT #######################
CONFIG_MP_VHT_HW_TX_MODE = n
###################### Platform Related #######################
CONFIG_PLATFORM_I386_PC = y
CONFIG_PLATFORM_ANDROID_X86 = n
CONFIG_PLATFORM_ANDROID_INTEL_X86 = n
CONFIG_PLATFORM_JB_X86 = n
CONFIG_PLATFORM_ARM_S3C2K4 = n
CONFIG_PLATFORM_ARM_PXA2XX = n
CONFIG_PLATFORM_ARM_S3C6K4 = n
CONFIG_PLATFORM_MIPS_RMI = n
CONFIG_PLATFORM_RTD2880B = n
CONFIG_PLATFORM_ARM_NV_NANO = n
CONFIG_PLATFORM_MIPS_AR9132 = n
CONFIG_PLATFORM_RTK_DMP = n
CONFIG_PLATFORM_MIPS_PLM = n
CONFIG_PLATFORM_MSTAR389 = n
CONFIG_PLATFORM_MT53XX = n
CONFIG_PLATFORM_ARM_RPI = n
CONFIG_PLATFORM_ARM_MX51_241H = n
CONFIG_PLATFORM_FS_MX61 = n
CONFIG_PLATFORM_ACTIONS_ATJ227X = n
CONFIG_PLATFORM_TEGRA3_CARDHU = n
CONFIG_PLATFORM_TEGRA4_DALMORE = n
CONFIG_PLATFORM_ARM_TCC8900 = n
CONFIG_PLATFORM_ARM_TCC8920 = n
CONFIG_PLATFORM_ARM_TCC8920_JB42 = n
CONFIG_PLATFORM_ARM_TCC8930_JB42 = n
CONFIG_PLATFORM_ARM_RK2818 = n
CONFIG_PLATFORM_ARM_RK3066 = n
CONFIG_PLATFORM_ARM_RK3188 = n
CONFIG_PLATFORM_ARM_RK3399 = n
CONFIG_PLATFORM_ARM_URBETTER = n
CONFIG_PLATFORM_ARM_TI_PANDA = n
CONFIG_PLATFORM_MIPS_JZ4760 = n
CONFIG_PLATFORM_DMP_PHILIPS = n
CONFIG_PLATFORM_MSTAR_TITANIA12 = n
CONFIG_PLATFORM_MSTAR = n
CONFIG_PLATFORM_SZEBOOK = n
CONFIG_PLATFORM_ARM_SUNxI = n
CONFIG_PLATFORM_ARM_SUN6I = n
CONFIG_PLATFORM_ARM_SUN7I = n
CONFIG_PLATFORM_ARM_SUN8I_W3P1 = n
CONFIG_PLATFORM_ARM_SUN8I_W5P1 = n
CONFIG_PLATFORM_ACTIONS_ATM702X = n
CONFIG_PLATFORM_ACTIONS_ATV5201 = n
CONFIG_PLATFORM_ACTIONS_ATM705X = n
CONFIG_PLATFORM_ARM_SUN50IW1P1 = n
CONFIG_PLATFORM_ARM_RTD299X = n
CONFIG_PLATFORM_ARM_LGE = n
CONFIG_PLATFORM_ARM_SPREADTRUM_6820 = n
CONFIG_PLATFORM_ARM_SPREADTRUM_8810 = n
CONFIG_PLATFORM_ARM_WMT = n
CONFIG_PLATFORM_TI_DM365 = n
CONFIG_PLATFORM_MOZART = n
CONFIG_PLATFORM_RTK119X = n
CONFIG_PLATFORM_RTK119X_AM = n
CONFIG_PLATFORM_RTK129X = n
CONFIG_PLATFORM_RTK390X = n
CONFIG_PLATFORM_NOVATEK_NT72668 = n
CONFIG_PLATFORM_HISILICON = n
CONFIG_PLATFORM_HISILICON_HI3798 = n
CONFIG_PLATFORM_NV_TK1 = n
CONFIG_PLATFORM_NV_TK1_UBUNTU = n
CONFIG_PLATFORM_RTL8197D = n
CONFIG_PLATFORM_AML_S905 = n
CONFIG_PLATFORM_ZTE_ZX296716 = n
########### CUSTOMER ################################
CONFIG_CUSTOMER_HUAWEI_GENERAL = n
CONFIG_DRVEXT_MODULE = n
export TopDIR ?= $(shell pwd)
########### COMMON  #################################
ifeq ($(CONFIG_GSPI_HCI), y)
HCI_NAME = gspi
endif
ifeq ($(CONFIG_SDIO_HCI), y)
HCI_NAME = sdio
endif
ifeq ($(CONFIG_USB_HCI), y)
HCI_NAME = usb
endif
ifeq ($(CONFIG_PCI_HCI), y)
HCI_NAME = pci
endif
_OS_INTFS_FILES :=	os_dep/osdep_service.o \
			os_dep/linux/os_intfs.o \
			os_dep/linux/$(HCI_NAME)_intf.o \
			os_dep/linux/$(HCI_NAME)_ops_linux.o \
			os_dep/linux/ioctl_linux.o \
			os_dep/linux/xmit_linux.o \
			os_dep/linux/mlme_linux.o \
			os_dep/linux/recv_linux.o \
			os_dep/linux/ioctl_cfg80211.o \
			os_dep/linux/rtw_cfgvendor.o \
			os_dep/linux/wifi_regd.o \
			os_dep/linux/rtw_android.o \
			os_dep/linux/rtw_proc.o \
			os_dep/linux/rtw_rhashtable.o
ifeq ($(CONFIG_MP_INCLUDED), y)
_OS_INTFS_FILES += os_dep/linux/ioctl_mp.o
endif
_OS_INTFS_FILES += os_dep/linux/custom_gpio_linux.o
_OS_INTFS_FILES += os_dep/linux/$(HCI_NAME)_ops_linux.o
endif
endif
_HAL_INTFS_FILES :=	hal/hal_intf.o \
			hal/hal_com.o \
			hal/hal_com_phycfg.o \
			hal/hal_phy.o \
			hal/hal_dm.o \
			hal/hal_dm_acs.o \
			hal/hal_btcoex_wifionly.o \
			hal/hal_btcoex.o \
			hal/hal_mp.o \
			hal/hal_mcc.o \
			hal/hal_hci/hal_$(HCI_NAME).o \
			hal/led/hal_led.o \
			hal/led/hal_$(HCI_NAME)_led.o
EXTRA_CFLAGS += -I$(src)/platform
_PLATFORM_FILES := platform/platform_ops.o
EXTRA_CFLAGS += -I$(src)/hal/btc
########### HAL_RTL8188E #################################
ifeq ($(CONFIG_RTL8188E), y)
RTL871X = rtl8188e
MODULE_NAME = 8189es
endif
endif
MODULE_NAME = 8188eu
endif
MODULE_NAME = 8188ee
endif
EXTRA_CFLAGS += -DCONFIG_RTL8188E
_HAL_INTFS_FILES +=	hal/HalPwrSeqCmd.o \
					hal/$(RTL871X)/Hal8188EPwrSeq.o\
 					hal/$(RTL871X)/$(RTL871X)_xmit.o\
					hal/$(RTL871X)/$(RTL871X)_sreset.o
_HAL_INTFS_FILES +=	hal/$(RTL871X)/$(RTL871X)_hal_init.o \
			hal/$(RTL871X)/$(RTL871X)_phycfg.o \
			hal/$(RTL871X)/$(RTL871X)_rf6052.o \
			hal/$(RTL871X)/$(RTL871X)_dm.o \
			hal/$(RTL871X)/$(RTL871X)_rxdesc.o \
			hal/$(RTL871X)/$(RTL871X)_cmd.o \
			hal/$(RTL871X)/hal8188e_s_fw.o \
			hal/$(RTL871X)/hal8188e_t_fw.o \
			hal/$(RTL871X)/$(HCI_NAME)/$(HCI_NAME)_halinit.o \
			hal/$(RTL871X)/$(HCI_NAME)/rtl$(MODULE_NAME)_led.o \
			hal/$(RTL871X)/$(HCI_NAME)/rtl$(MODULE_NAME)_xmit.o \
			hal/$(RTL871X)/$(HCI_NAME)/rtl$(MODULE_NAME)_recv.o
_HAL_INTFS_FILES += hal/$(RTL871X)/$(HCI_NAME)/$(HCI_NAME)_ops.o
else
else
_HAL_INTFS_FILES += hal/$(RTL871X)/$(HCI_NAME)/$(HCI_NAME)_ops_linux.o
endif
endif
_HAL_INTFS_FILES +=hal/efuse/$(RTL871X)/HalEfuseMask8188E_USB.o
endif
_HAL_INTFS_FILES +=hal/efuse/$(RTL871X)/HalEfuseMask8188E_PCIE.o
endif
_HAL_INTFS_FILES +=hal/efuse/$(RTL871X)/HalEfuseMask8188E_SDIO.o
endif
endif
########### HAL_RTL8192E #################################
ifeq ($(CONFIG_RTL8192E), y)
RTL871X = rtl8192e
MODULE_NAME = 8192es
endif
MODULE_NAME = 8192eu
endif
MODULE_NAME = 8192ee
endif
EXTRA_CFLAGS += -DCONFIG_RTL8192E
					hal/$(RTL871X)/Hal8192EPwrSeq.o\
			hal/$(RTL871X)/hal8192e_fw.o \
else
else
endif
endif
_HAL_INTFS_FILES +=hal/efuse/$(RTL871X)/HalEfuseMask8192E_USB.o
endif
_HAL_INTFS_FILES +=hal/efuse/$(RTL871X)/HalEfuseMask8192E_PCIE.o
endif
_HAL_INTFS_FILES +=hal/efuse/$(RTL871X)/HalEfuseMask8192E_SDIO.o
endif
ifeq ($(CONFIG_BT_COEXIST), y)
_BTC_FILES += hal/btc/halbtc8192e1ant.o \
				hal/btc/halbtc8192e2ant.o
endif
endif
########### HAL_RTL8812A_RTL8821A #################################
ifneq ($(CONFIG_RTL8812A)_$(CONFIG_RTL8821A), n_n)
RTL871X = rtl8812a
MODULE_NAME = 8812au
endif
MODULE_NAME = 8812ae
endif
MODULE_NAME = 8812as
endif
					hal/$(RTL871X)/Hal8812PwrSeq.o \
					hal/$(RTL871X)/Hal8821APwrSeq.o\
else
else
endif
endif
ifeq ($(CONFIG_RTL8812A), y)
_HAL_INTFS_FILES +=hal/efuse/$(RTL871X)/HalEfuseMask8812A_USB.o
endif
_HAL_INTFS_FILES +=hal/efuse/$(RTL871X)/HalEfuseMask8812A_PCIE.o
endif
endif
ifeq ($(CONFIG_RTL8821A), y)
_HAL_INTFS_FILES +=hal/efuse/$(RTL871X)/HalEfuseMask8821A_USB.o
endif
_HAL_INTFS_FILES +=hal/efuse/$(RTL871X)/HalEfuseMask8821A_PCIE.o
endif
_HAL_INTFS_FILES +=hal/efuse/$(RTL871X)/HalEfuseMask8821A_SDIO.o
endif
endif
EXTRA_CFLAGS += -DCONFIG_RTL8812A
_HAL_INTFS_FILES +=	hal/rtl8812a/hal8812a_fw.o
endif
ifeq ($(CONFIG_RTL8812A), n)
RTL871X = rtl8821a
MODULE_NAME := 8821au
else
MODULE_NAME := 8811au
endif
endif
MODULE_NAME := 8821ae
endif
MODULE_NAME := 8821as
endif
endif
EXTRA_CFLAGS += -DCONFIG_RTL8821A
_HAL_INTFS_FILES +=	hal/rtl8812a/hal8821a_fw.o
endif
_BTC_FILES += hal/btc/halbtc8812a1ant.o \
				hal/btc/halbtc8812a2ant.o
endif
_BTC_FILES += hal/btc/halbtc8821a1ant.o \
				hal/btc/halbtc8821a2ant.o
endif
endif
endif
########### HAL_RTL8723B #################################
ifeq ($(CONFIG_RTL8723B), y)
RTL871X = rtl8723b
MODULE_NAME = 8723bu
endif
MODULE_NAME = 8723be
endif
MODULE_NAME = 8723bs
endif
EXTRA_CFLAGS += -DCONFIG_RTL8723B
					hal/$(RTL871X)/Hal8723BPwrSeq.o\
			hal/$(RTL871X)/hal8723b_fw.o
_HAL_INTFS_FILES +=	\
else
endif
_HAL_INTFS_FILES +=hal/efuse/$(RTL871X)/HalEfuseMask8723B_USB.o
endif
_HAL_INTFS_FILES +=hal/efuse/$(RTL871X)/HalEfuseMask8723B_PCIE.o
endif
_HAL_INTFS_FILES +=hal/efuse/$(RTL871X)/HalEfuseMask8723B_SDIO.o
endif
_BTC_FILES += hal/btc/halbtc8723bwifionly.o
_BTC_FILES += hal/btc/halbtc8723b1ant.o \
				hal/btc/halbtc8723b2ant.o
endif
endif
########### HAL_RTL8814A #################################
ifeq ($(CONFIG_RTL8814A), y)
## ADD NEW VHT MP HW TX MODE ##
#EXTRA_CFLAGS += -DCONFIG_MP_VHT_HW_TX_MODE
#CONFIG_MP_VHT_HW_TX_MODE = y
RTL871X = rtl8814a
MODULE_NAME = 8814au
endif
MODULE_NAME = 8814ae
endif
MODULE_NAME = 8814as
endif
EXTRA_CFLAGS += -DCONFIG_RTL8814A
					hal/$(RTL871X)/Hal8814PwrSeq.o \
			hal/$(RTL871X)/hal8814a_fw.o
else
else
endif
endif
_HAL_INTFS_FILES +=hal/efuse/$(RTL871X)/HalEfuseMask8814A_USB.o
endif
_HAL_INTFS_FILES +=hal/efuse/$(RTL871X)/HalEfuseMask8814A_PCIE.o
endif
_BTC_FILES += hal/btc/halbtc8814a2ant.o
endif
endif
########### HAL_RTL8723C #################################
ifeq ($(CONFIG_RTL8723C), y)
RTL871X = rtl8703b
MODULE_NAME = 8723cu
MODULE_SUB_NAME = 8703bu
endif
MODULE_NAME = 8723ce
MODULE_SUB_NAME = 8703be
endif
MODULE_NAME = 8723cs
MODULE_SUB_NAME = 8703bs
endif
EXTRA_CFLAGS += -DCONFIG_RTL8703B
					hal/$(RTL871X)/Hal8703BPwrSeq.o\
			hal/$(RTL871X)/hal8703b_fw.o
			hal/$(RTL871X)/$(HCI_NAME)/rtl$(MODULE_SUB_NAME)_led.o \
			hal/$(RTL871X)/$(HCI_NAME)/rtl$(MODULE_SUB_NAME)_xmit.o \
			hal/$(RTL871X)/$(HCI_NAME)/rtl$(MODULE_SUB_NAME)_recv.o
else
endif
_HAL_INTFS_FILES +=hal/efuse/$(RTL871X)/HalEfuseMask8703B_USB.o
endif
_HAL_INTFS_FILES +=hal/efuse/$(RTL871X)/HalEfuseMask8703B_PCIE.o
endif
_BTC_FILES += hal/btc/halbtc8703b1ant.o
endif
endif
########### HAL_RTL8723D #################################
ifeq ($(CONFIG_RTL8723D), y)
RTL871X = rtl8723d
MODULE_NAME = 8723du
MODULE_SUB_NAME = 8723du
endif
MODULE_NAME = 8723de
MODULE_SUB_NAME = 8723de
endif
MODULE_NAME = 8723ds
MODULE_SUB_NAME = 8723ds
endif
EXTRA_CFLAGS += -DCONFIG_RTL8723D
					hal/$(RTL871X)/Hal8723DPwrSeq.o\
			hal/$(RTL871X)/hal8723d_fw.o \
			hal/$(RTL871X)/$(RTL871X)_lps_poff.o
else
endif
_HAL_INTFS_FILES +=hal/efuse/$(RTL871X)/HalEfuseMask8723D_USB.o
endif
_HAL_INTFS_FILES +=hal/efuse/$(RTL871X)/HalEfuseMask8723D_PCIE.o
endif
_BTC_FILES += hal/btc/halbtc8723d1ant.o \
				hal/btc/halbtc8723d2ant.o
endif
endif
########### HAL_RTL8188F #################################
ifeq ($(CONFIG_RTL8188F), y)
RTL871X = rtl8188f
MODULE_NAME = 8188fu
endif
MODULE_NAME = 8188fe
endif
MODULE_NAME = 8189fs
endif
EXTRA_CFLAGS += -DCONFIG_RTL8188F
					hal/$(RTL871X)/Hal8188FPwrSeq.o\
			hal/$(RTL871X)/hal8188f_fw.o
else
endif
_HAL_INTFS_FILES +=hal/efuse/$(RTL871X)/HalEfuseMask8188F_USB.o
endif
_HAL_INTFS_FILES +=hal/efuse/$(RTL871X)/HalEfuseMask8188F_SDIO.o
endif
endif
########### HAL_RTL8188GTV #################################
ifeq ($(CONFIG_RTL8188GTV), y)
RTL871X = rtl8188gtv
MODULE_NAME = 8188gtvu
endif
MODULE_NAME = 8189gtvs
endif
EXTRA_CFLAGS += -DCONFIG_RTL8188GTV
					hal/$(RTL871X)/Hal8188GTVPwrSeq.o\
			hal/$(RTL871X)/hal8188gtv_fw.o
else
endif
_HAL_INTFS_FILES +=hal/efuse/$(RTL871X)/HalEfuseMask8188GTV_USB.o
endif
_HAL_INTFS_FILES +=hal/efuse/$(RTL871X)/HalEfuseMask8188GTV_SDIO.o
endif
endif
########### HAL_RTL8822B #################################
ifeq ($(CONFIG_RTL8822B), y)
RTL871X := rtl8822b
ifeq ($(CONFIG_BT_COEXIST), n)
MODULE_NAME = 8812bu
else
MODULE_NAME = 88x2bu
endif
endif
MODULE_NAME = 88x2be
endif
MODULE_NAME = 88x2bs
endif
endif
########### HAL_RTL8821C #################################
ifeq ($(CONFIG_RTL8821C), y)
RTL871X := rtl8821c
MODULE_NAME = 8821cu
endif
MODULE_NAME = 8821ce
endif
MODULE_NAME = 8821cs
endif
endif
########### HAL_RTL8710B #################################
ifeq ($(CONFIG_RTL8710B), y)
RTL871X = rtl8710b
MODULE_NAME = 8710bu
MODULE_SUB_NAME = 8710bu
endif
EXTRA_CFLAGS += -DCONFIG_RTL8710B
					hal/$(RTL871X)/Hal8710BPwrSeq.o\
			hal/$(RTL871X)/hal8710b_fw.o \
_HAL_INTFS_FILES +=hal/efuse/$(RTL871X)/HalEfuseMask8710B_USB.o
endif
endif
########### HAL_RTL8192F #################################
ifeq ($(CONFIG_RTL8192F), y)
RTL871X = rtl8192f
MODULE_NAME = 8192fu
MODULE_SUB_NAME = 8192fu
endif
MODULE_NAME = 8192fe
MODULE_SUB_NAME = 8192fe
endif
MODULE_NAME = 8192fs
MODULE_SUB_NAME = 8192fs
endif
EXTRA_CFLAGS += -DCONFIG_RTL8192F
					hal/$(RTL871X)/Hal8192FPwrSeq.o\
			hal/$(RTL871X)/hal8192f_fw.o \
else
endif
_HAL_INTFS_FILES += hal/efuse/$(RTL871X)/HalEfuseMask8192F_SDIO.o
endif
_HAL_INTFS_FILES += hal/efuse/$(RTL871X)/HalEfuseMask8192F_USB.o
endif
_HAL_INTFS_FILES += hal/efuse/$(RTL871X)/HalEfuseMask8192F_PCIE.o
endif
_BTC_FILES += hal/btc/halbtccommon.o \
				hal/btc/halbtc8192f.o
endif
endif
########### HAL_RTL8822C #################################
ifeq ($(CONFIG_RTL8822C), y)
RTL871X := rtl8822c
MODULE_NAME = 8812cu
else
MODULE_NAME = 88x2cu
endif
endif
MODULE_NAME = 88x2ce
endif
MODULE_NAME = 88x2cs
endif
endif
########### HAL_RTL8814B #################################
ifeq ($(CONFIG_RTL8814B), y)
RTL871X := rtl8814b
MODULE_NAME = 8814bu
endif
MODULE_NAME = 8814be
endif
endif
########### AUTO_CFG  #################################
ifeq ($(CONFIG_AUTOCFG_CP), y)
ifeq ($(CONFIG_MULTIDRV), y)
$(shell cp $(TopDIR)/autoconf_multidrv_$(HCI_NAME)_linux.h $(TopDIR)/include/autoconf.h)
else
ifeq ($(CONFIG_RTL8188E)$(CONFIG_SDIO_HCI),yy)
$(shell cp $(TopDIR)/autoconf_rtl8189e_$(HCI_NAME)_linux.h $(TopDIR)/include/autoconf.h)
else ifeq ($(CONFIG_RTL8188F)$(CONFIG_SDIO_HCI),yy)
$(shell cp $(TopDIR)/autoconf_rtl8189f_$(HCI_NAME)_linux.h $(TopDIR)/include/autoconf.h)
else ifeq ($(CONFIG_RTL8723C),y)
$(shell cp $(TopDIR)/autoconf_rtl8723c_$(HCI_NAME)_linux.h $(TopDIR)/include/autoconf.h)
else
$(shell cp $(TopDIR)/autoconf_$(RTL871X)_$(HCI_NAME)_linux.h $(TopDIR)/include/autoconf.h)
endif
endif
endif
########### END OF PATH  #################################
ifeq ($(CONFIG_USB_AUTOSUSPEND), y)
EXTRA_CFLAGS += -DCONFIG_USB_AUTOSUSPEND
endif
endif
#MODULE_NAME := $(MODULE_NAME)_mp
EXTRA_CFLAGS += -DCONFIG_MP_INCLUDED
endif
ifeq ($(CONFIG_POWER_SAVING), y)
ifneq ($(CONFIG_IPS_MODE), default)
EXTRA_CFLAGS += -DRTW_IPS_MODE=$(CONFIG_IPS_MODE)
endif
ifneq ($(CONFIG_LPS_MODE), default)
EXTRA_CFLAGS += -DRTW_LPS_MODE=$(CONFIG_LPS_MODE)
endif
ifneq ($(CONFIG_WOW_LPS_MODE), default)
EXTRA_CFLAGS += -DRTW_WOW_LPS_MODE=$(CONFIG_WOW_LPS_MODE)
endif
EXTRA_CFLAGS += -DCONFIG_POWER_SAVING
endif
ifeq ($(CONFIG_HW_PWRP_DETECTION), y)
EXTRA_CFLAGS += -DCONFIG_HW_PWRP_DETECTION
endif
EXTRA_CFLAGS += -DCONFIG_BT_COEXIST
endif
ifeq ($(CONFIG_WAPI_SUPPORT), y)
EXTRA_CFLAGS += -DCONFIG_WAPI_SUPPORT
endif
ifeq ($(CONFIG_EFUSE_CONFIG_FILE), y)
EXTRA_CFLAGS += -DCONFIG_EFUSE_CONFIG_FILE
#EFUSE_MAP_PATH
USER_EFUSE_MAP_PATH ?=
ifneq ($(USER_EFUSE_MAP_PATH),)
EXTRA_CFLAGS += -DEFUSE_MAP_PATH=\"$(USER_EFUSE_MAP_PATH)\"
else ifeq ($(MODULE_NAME), 8189es)
EXTRA_CFLAGS += -DEFUSE_MAP_PATH=\"/system/etc/wifi/wifi_efuse_8189e.map\"
else ifeq ($(MODULE_NAME), 8723bs)
EXTRA_CFLAGS += -DEFUSE_MAP_PATH=\"/system/etc/wifi/wifi_efuse_8723bs.map\"
else
EXTRA_CFLAGS += -DEFUSE_MAP_PATH=\"/system/etc/wifi/wifi_efuse_$(MODULE_NAME).map\"
endif
#WIFIMAC_PATH
USER_WIFIMAC_PATH ?=
ifneq ($(USER_WIFIMAC_PATH),)
EXTRA_CFLAGS += -DWIFIMAC_PATH=\"$(USER_WIFIMAC_PATH)\"
else
EXTRA_CFLAGS += -DWIFIMAC_PATH=\"/data/wifimac.txt\"
endif
endif
ifeq ($(CONFIG_EXT_CLK), y)
EXTRA_CFLAGS += -DCONFIG_EXT_CLK
endif
ifeq ($(CONFIG_TRAFFIC_PROTECT), y)
EXTRA_CFLAGS += -DCONFIG_TRAFFIC_PROTECT
endif
ifeq ($(CONFIG_LOAD_PHY_PARA_FROM_FILE), y)
EXTRA_CFLAGS += -DCONFIG_LOAD_PHY_PARA_FROM_FILE
#EXTRA_CFLAGS += -DREALTEK_CONFIG_PATH_WITH_IC_NAME_FOLDER
EXTRA_CFLAGS += -DREALTEK_CONFIG_PATH=\"/lib/firmware/\"
endif
ifeq ($(CONFIG_TXPWR_BY_RATE), n)
EXTRA_CFLAGS += -DCONFIG_TXPWR_BY_RATE=0
else ifeq ($(CONFIG_TXPWR_BY_RATE), y)
EXTRA_CFLAGS += -DCONFIG_TXPWR_BY_RATE=1
endif
ifeq ($(CONFIG_TXPWR_BY_RATE_EN), n)
EXTRA_CFLAGS += -DCONFIG_TXPWR_BY_RATE_EN=0
else ifeq ($(CONFIG_TXPWR_BY_RATE_EN), y)
EXTRA_CFLAGS += -DCONFIG_TXPWR_BY_RATE_EN=1
else ifeq ($(CONFIG_TXPWR_BY_RATE_EN), auto)
EXTRA_CFLAGS += -DCONFIG_TXPWR_BY_RATE_EN=2
endif
ifeq ($(CONFIG_TXPWR_LIMIT), n)
EXTRA_CFLAGS += -DCONFIG_TXPWR_LIMIT=0
else ifeq ($(CONFIG_TXPWR_LIMIT), y)
EXTRA_CFLAGS += -DCONFIG_TXPWR_LIMIT=1
endif
ifeq ($(CONFIG_TXPWR_LIMIT_EN), n)
EXTRA_CFLAGS += -DCONFIG_TXPWR_LIMIT_EN=0
else ifeq ($(CONFIG_TXPWR_LIMIT_EN), y)
EXTRA_CFLAGS += -DCONFIG_TXPWR_LIMIT_EN=1
else ifeq ($(CONFIG_TXPWR_LIMIT_EN), auto)
EXTRA_CFLAGS += -DCONFIG_TXPWR_LIMIT_EN=2
endif
ifneq ($(CONFIG_RTW_CHPLAN), 0xFF)
EXTRA_CFLAGS += -DCONFIG_RTW_CHPLAN=$(CONFIG_RTW_CHPLAN)
endif
ifeq ($(CONFIG_CALIBRATE_TX_POWER_BY_REGULATORY), y)
EXTRA_CFLAGS += -DCONFIG_CALIBRATE_TX_POWER_BY_REGULATORY
endif
ifeq ($(CONFIG_CALIBRATE_TX_POWER_TO_MAX), y)
EXTRA_CFLAGS += -DCONFIG_CALIBRATE_TX_POWER_TO_MAX
endif
ifeq ($(CONFIG_RTW_ADAPTIVITY_EN), disable)
EXTRA_CFLAGS += -DCONFIG_RTW_ADAPTIVITY_EN=0
else ifeq ($(CONFIG_RTW_ADAPTIVITY_EN), enable)
EXTRA_CFLAGS += -DCONFIG_RTW_ADAPTIVITY_EN=1
endif
ifeq ($(CONFIG_RTW_ADAPTIVITY_MODE), normal)
EXTRA_CFLAGS += -DCONFIG_RTW_ADAPTIVITY_MODE=0
else ifeq ($(CONFIG_RTW_ADAPTIVITY_MODE), carrier_sense)
EXTRA_CFLAGS += -DCONFIG_RTW_ADAPTIVITY_MODE=1
endif
ifeq ($(CONFIG_SIGNAL_SCALE_MAPPING), y)
EXTRA_CFLAGS += -DCONFIG_SIGNAL_SCALE_MAPPING
endif
ifeq ($(CONFIG_80211W), y)
EXTRA_CFLAGS += -DCONFIG_IEEE80211W
endif
ifeq ($(CONFIG_WOWLAN), y)
EXTRA_CFLAGS += -DCONFIG_WOWLAN -DRTW_WAKEUP_EVENT=$(CONFIG_WAKEUP_TYPE)
EXTRA_CFLAGS += -DRTW_SUSPEND_TYPE=$(CONFIG_SUSPEND_TYPE)
ifeq ($(CONFIG_WOW_STA_MIX), y)
EXTRA_CFLAGS += -DRTW_WOW_STA_MIX
endif
EXTRA_CFLAGS += -DCONFIG_RTW_SDIO_PM_KEEP_POWER
endif
endif
ifeq ($(CONFIG_AP_WOWLAN), y)
EXTRA_CFLAGS += -DCONFIG_AP_WOWLAN
endif
endif
ifeq ($(CONFIG_PNO_SUPPORT), y)
EXTRA_CFLAGS += -DCONFIG_PNO_SUPPORT
ifeq ($(CONFIG_PNO_SET_DEBUG), y)
EXTRA_CFLAGS += -DCONFIG_PNO_SET_DEBUG
endif
endif
ifeq ($(CONFIG_GPIO_WAKEUP), y)
EXTRA_CFLAGS += -DCONFIG_GPIO_WAKEUP
ifeq ($(CONFIG_ONE_PIN_GPIO), y)
EXTRA_CFLAGS += -DCONFIG_RTW_ONE_PIN_GPIO
endif
ifeq ($(CONFIG_HIGH_ACTIVE_DEV2HST), y)
EXTRA_CFLAGS += -DHIGH_ACTIVE_DEV2HST=1
else
EXTRA_CFLAGS += -DHIGH_ACTIVE_DEV2HST=0
endif
endif
ifeq ($(CONFIG_HIGH_ACTIVE_HST2DEV), y)
EXTRA_CFLAGS += -DHIGH_ACTIVE_HST2DEV=1
else
EXTRA_CFLAGS += -DHIGH_ACTIVE_HST2DEV=0
endif
ifneq ($(CONFIG_WAKEUP_GPIO_IDX), default)
EXTRA_CFLAGS += -DWAKEUP_GPIO_IDX=$(CONFIG_WAKEUP_GPIO_IDX)
endif
ifeq ($(CONFIG_RTW_SDIO_PM_KEEP_POWER), y)
endif
endif
ifeq ($(CONFIG_REDUCE_TX_CPU_LOADING), y)
EXTRA_CFLAGS += -DCONFIG_REDUCE_TX_CPU_LOADING
endif
ifeq ($(CONFIG_BR_EXT), y)
BR_NAME = br0
EXTRA_CFLAGS += -DCONFIG_BR_EXT
EXTRA_CFLAGS += '-DCONFIG_BR_EXT_BRNAME="'$(BR_NAME)'"'
endif
ifeq ($(CONFIG_TDLS), y)
EXTRA_CFLAGS += -DCONFIG_TDLS
endif
ifeq ($(CONFIG_WIFI_MONITOR), y)
EXTRA_CFLAGS += -DCONFIG_WIFI_MONITOR
endif
ifeq ($(CONFIG_MCC_MODE), y)
EXTRA_CFLAGS += -DCONFIG_MCC_MODE
endif
ifeq ($(CONFIG_RTW_NAPI), y)
EXTRA_CFLAGS += -DCONFIG_RTW_NAPI
endif
ifeq ($(CONFIG_RTW_GRO), y)
EXTRA_CFLAGS += -DCONFIG_RTW_GRO
endif
ifeq ($(CONFIG_RTW_REPEATER_SON), y)
EXTRA_CFLAGS += -DCONFIG_RTW_REPEATER_SON
endif
ifeq ($(CONFIG_RTW_IPCAM_APPLICATION), y)
EXTRA_CFLAGS += -DCONFIG_RTW_IPCAM_APPLICATION
ifeq ($(CONFIG_WIFI_MONITOR), n)
endif
endif
ifeq ($(CONFIG_RTW_NETIF_SG), y)
EXTRA_CFLAGS += -DCONFIG_RTW_NETIF_SG
endif
ifeq ($(CONFIG_ICMP_VOQ), y)
EXTRA_CFLAGS += -DCONFIG_ICMP_VOQ
endif
ifeq ($(CONFIG_IP_R_MONITOR), y)
EXTRA_CFLAGS += -DCONFIG_IP_R_MONITOR
endif
ifeq ($(CONFIG_RTW_WIFI_HAL), y)
#EXTRA_CFLAGS += -DCONFIG_RTW_WIFI_HAL_DEBUG
EXTRA_CFLAGS += -DCONFIG_RTW_CFGVEDNOR_LLSTATS
EXTRA_CFLAGS += -DCONFIG_RTW_CFGVENDOR_RANDOM_MAC_OUI
EXTRA_CFLAGS += -DCONFIG_RTW_CFGVEDNOR_RSSIMONITOR
EXTRA_CFLAGS += -DCONFIG_RTW_CFGVENDOR_WIFI_LOGGER
endif
ifeq ($(CONFIG_MP_VHT_HW_TX_MODE), y)
ifeq ($(CONFIG_PLATFORM_I386_PC), y)
## For I386 X86 ToolChain use Hardware FLOATING
EXTRA_CFLAGS += -mhard-float
else
## For ARM ToolChain use Hardware FLOATING
EXTRA_CFLAGS += -mfloat-abi=hard
endif
endif
ifeq ($(CONFIG_APPEND_VENDOR_IE_ENABLE), y)
EXTRA_CFLAGS += -DCONFIG_APPEND_VENDOR_IE_ENABLE
endif
ifeq ($(CONFIG_RTW_DEBUG), y)
EXTRA_CFLAGS += -DCONFIG_RTW_DEBUG
EXTRA_CFLAGS += -DRTW_LOG_LEVEL=$(CONFIG_RTW_LOG_LEVEL)
endif
ifeq ($(CONFIG_PROC_DEBUG), y)
EXTRA_CFLAGS += -DCONFIG_PROC_DEBUG
endif
ifeq ($(CONFIG_RTW_UP_MAPPING_RULE), dscp)
EXTRA_CFLAGS += -DCONFIG_RTW_UP_MAPPING_RULE=1
else
EXTRA_CFLAGS += -DCONFIG_RTW_UP_MAPPING_RULE=0
endif
EXTRA_CFLAGS += -DDM_ODM_SUPPORT_TYPE=0x04
ifeq ($(CONFIG_RTW_VHT_2G4), y)
EXTRA_CFLAGS += -DRTW_VHT_2G4=1
else
EXTRA_CFLAGS += -DRTW_VHT_2G4=0
endif
ifeq (y, $(filter y, $(CONFIG_PLATFORM_I386_PC) $(CONFIG_PLATFORM_ARM_NV_NANO) $(CONFIG_PLATFORM_ARM_RPI)))
EXTRA_CFLAGS += -DCONFIG_LITTLE_ENDIAN
EXTRA_CFLAGS += -DCONFIG_IOCTL_CFG80211 -DRTW_USE_CFG80211_STA_EVENT
ARCH := $(shell uname -m | sed -e s/i.86/i386/)
ifneq ($(CONFIG_PLATFORM_I386_PC), y)
	_WARNING := $(warning ARM_RPI or ARM_NV_NANO requested. Must disable -Werror.)
	EXTRA_CFLAGS += -Wno-error
	ARCH := arm64
	ifeq ($(CONFIG_PLATFORM_ARM_RPI), y)
		ifneq ($(shell uname -m), aarch64)
			ARCH := arm
		endif
	endif
endif
CROSS_COMPILE ?=
KVER  ?= $(shell uname -r)
ifeq ($(KBASE),)
	KBASE = /lib/modules/$(KVER)
	KSRC = $(KBASE)/build
	MODDESTDIR = $(KBASE)/kernel/drivers/net/wireless/
	STAGINGMODDIR = $(KBASE)/kernel/drivers/staging
else
	KSRC = $(KBASE)
	MODDESTDIR = $(KBASE)/drivers/net/wireless/
	STAGINGMODDIR = $(KBASE)/drivers/staging
endif
INSTALL_PREFIX :=
endif
ifeq ($(CONFIG_PLATFORM_NV_TK1), y)
EXTRA_CFLAGS += -DCONFIG_PLATFORM_NV_TK1
# default setting for Android 4.1, 4.2
EXTRA_CFLAGS += -DCONFIG_CONCURRENT_MODE
EXTRA_CFLAGS += -DCONFIG_P2P_IPS -DCONFIG_PLATFORM_ANDROID
# Enable this for Android 5.0
EXTRA_CFLAGS += -DCONFIG_RADIO_WORK
EXTRA_CFLAGS += -DRTW_VENDOR_EXT_SUPPORT
EXTRA_CFLAGS += -DRTW_ENABLE_WIFI_CONTROL_FUNC
ARCH ?= arm
CROSS_COMPILE := /mnt/newdisk/android_sdk/nvidia_tk1/android_L/prebuilts/gcc/linux-x86/arm/arm-eabi-4.8/bin/arm-eabi-
KSRC :=/mnt/newdisk/android_sdk/nvidia_tk1/android_L/out/target/product/shieldtablet/obj/KERNEL/
MODULE_NAME = wlan
endif
ifeq ($(CONFIG_PLATFORM_NV_TK1_UBUNTU), y)
ARCH ?= arm
CROSS_COMPILE ?=
KVER := $(shell uname -r)
KSRC := /lib/modules/$(KVER)/build
MODDESTDIR := /lib/modules/$(KVER)/kernel/drivers/net/wireless/
INSTALL_PREFIX :=
endif
ifeq ($(CONFIG_PLATFORM_ACTIONS_ATM702X), y)
EXTRA_CFLAGS += -DCONFIG_LITTLE_ENDIAN -DCONFIG_PLATFORM_ANDROID -DCONFIG_PLATFORM_ACTIONS_ATM702X
#ARCH := arm
ARCH := $(R_ARCH)
#CROSS_COMPILE := arm-none-linux-gnueabi-
CROSS_COMPILE := $(R_CROSS_COMPILE)
KVER:= 3.4.0
#KSRC := ../../../../build/out/kernel
KSRC := $(KERNEL_BUILD_PATH)
MODULE_NAME :=wlan
endif
ifeq ($(CONFIG_PLATFORM_ACTIONS_ATM705X), y)
#EXTRA_CFLAGS += -DRTW_ENABLE_WIFI_CONTROL_FUNC
# default setting for Android 4.1, 4.2, 4.3, 4.4
EXTRA_CFLAGS += -DCONFIG_PLATFORM_ACTIONS_ATM705X
EXTRA_CFLAGS += -DCONFIG_PLATFORM_OPS
_PLATFORM_FILES += platform/platform_arm_act_sdio.o
endif
ARCH := arm
CROSS_COMPILE := /opt/arm-2011.09/bin/arm-none-linux-gnueabi-
KSRC := /home/android_sdk/Action-semi/705a_android_L/android/kernel
endif
ifeq ($(CONFIG_PLATFORM_ARM_SUN50IW1P1), y)
EXTRA_CFLAGS += -DCONFIG_PLATFORM_ARM_SUN50IW1P1
EXTRA_CFLAGS += -DCONFIG_RESUME_IN_WORKQUEUE
EXTRA_CFLAGS += -DCONFIG_USE_USB_BUFFER_ALLOC_TX
_PLATFORM_FILES += platform/platform_ARM_SUNxI_usb.o
endif
_PLATFORM_FILES += platform/platform_ARM_SUN50IW1P1_sdio.o
endif
ARCH := arm64
# ===Cross compile setting for Android 5.1(64) SDK ===
CROSS_COMPILE := /home/android_sdk/Allwinner/a64/android-51/lichee/out/sun50iw1p1/android/common/buildroot/external-toolchain/bin/aarch64-linux-gnu-
KSRC :=/home/android_sdk/Allwinner/a64/android-51/lichee/linux-3.10/
endif
ifeq ($(CONFIG_PLATFORM_TI_AM3517), y)
EXTRA_CFLAGS += -DCONFIG_LITTLE_ENDIAN -DCONFIG_PLATFORM_ANDROID -DCONFIG_PLATFORM_SHUTTLE
CROSS_COMPILE := arm-eabi-
KSRC := $(shell pwd)/../../../Android/kernel
ARCH := arm
endif
ifeq ($(CONFIG_PLATFORM_MSTAR_TITANIA12), y)
EXTRA_CFLAGS += -DCONFIG_LITTLE_ENDIAN -DCONFIG_PLATFORM_MSTAR -DCONFIG_PLATFORM_MSTAR_TITANIA12
ARCH:=mips
CROSS_COMPILE:= /usr/src/Mstar_kernel/mips-4.3/bin/mips-linux-gnu-
KVER:= 2.6.28.9
KSRC:= /usr/src/Mstar_kernel/2.6.28.9/
endif
ifeq ($(CONFIG_PLATFORM_MSTAR), y)
EXTRA_CFLAGS += -DCONFIG_PLATFORM_MSTAR
EXTRA_CFLAGS += -DCONFIG_PLATFORM_MSTAR_HIGH
EXTRA_CFLAGS += -DCONFIG_USE_USB_BUFFER_ALLOC_TX -DCONFIG_FIX_NR_BULKIN_BUFFER
endif
ARCH:=arm
CROSS_COMPILE:= /usr/src/bin/arm-none-linux-gnueabi-
KVER:= 3.1.10
KSRC:= /usr/src/Mstar_kernel/3.1.10/
endif
ifeq ($(CONFIG_PLATFORM_ANDROID_X86), y)
SUBARCH := $(shell uname -m | sed -e s/i.86/i386/)
ARCH := $(SUBARCH)
CROSS_COMPILE := /media/DATA-2/android-x86/ics-x86_20120130/prebuilt/linux-x86/toolchain/i686-unknown-linux-gnu-4.2.1/bin/i686-unknown-linux-gnu-
KSRC := /media/DATA-2/android-x86/ics-x86_20120130/out/target/product/generic_x86/obj/kernel
MODULE_NAME :=wlan
endif
ifeq ($(CONFIG_PLATFORM_ANDROID_INTEL_X86), y)
EXTRA_CFLAGS += -DCONFIG_PLATFORM_ANDROID_INTEL_X86
EXTRA_CFLAGS += -DCONFIG_PLATFORM_INTEL_BYT
EXTRA_CFLAGS += -DCONFIG_SKIP_SIGNAL_SCALE_MAPPING
endif
endif
ifeq ($(CONFIG_PLATFORM_JB_X86), y)
ARCH := $(SUBARCH)
CROSS_COMPILE := /home/android_sdk/android-x86_JB/prebuilts/gcc/linux-x86/x86/i686-linux-android-4.7/bin/i686-linux-android-
KSRC := /home/android_sdk/android-x86_JB/out/target/product/x86/obj/kernel/
MODULE_NAME :=wlan
endif
ifeq ($(CONFIG_PLATFORM_ARM_PXA2XX), y)
ARCH := arm
KVER  := 2.6.34.1
KSRC ?= /usr/src/linux-2.6.34.1
endif
ifeq ($(CONFIG_PLATFORM_ARM_S3C2K4), y)
ARCH := arm
CROSS_COMPILE := arm-linux-
KVER  := 2.6.24.7_$(ARCH)
KSRC := /usr/src/kernels/linux-$(KVER)
endif
ifeq ($(CONFIG_PLATFORM_ARM_S3C6K4), y)
ARCH := arm
KVER  := 2.6.34.1
endif
ifeq ($(CONFIG_PLATFORM_RTD2880B), y)
EXTRA_CFLAGS += -DCONFIG_BIG_ENDIAN -DCONFIG_PLATFORM_RTD2880B
ARCH:=
CROSS_COMPILE:=
KVER:=
KSRC:=
endif
ifeq ($(CONFIG_PLATFORM_MIPS_RMI), y)
ARCH:=mips
CROSS_COMPILE:=mipsisa32r2-uclibc-
KVER:=
KSRC:= /root/work/kernel_realtek
endif
ifeq ($(CONFIG_PLATFORM_MIPS_PLM), y)
ARCH:=mips
KVER:=
endif
ifeq ($(CONFIG_PLATFORM_MSTAR389), y)
EXTRA_CFLAGS += -DCONFIG_LITTLE_ENDIAN -DCONFIG_PLATFORM_MSTAR389
ARCH:=mips
CROSS_COMPILE:= mips-linux-gnu-
KVER:= 2.6.28.10
KSRC:= /home/mstar/mstar_linux/2.6.28.9/
endif
ifeq ($(CONFIG_PLATFORM_MIPS_AR9132), y)
ARCH := mips
CROSS_COMPILE := mips-openwrt-linux-
KSRC := /home/alex/test_openwrt/tmp/linux-2.6.30.9
endif
ifeq ($(CONFIG_PLATFORM_DMP_PHILIPS), y)
EXTRA_CFLAGS += -DCONFIG_LITTLE_ENDIAN -DRTK_DMP_PLATFORM
ARCH := mips
#CROSS_COMPILE:=/usr/local/msdk-4.3.6-mips-EL-2.6.12.6-0.9.30.3/bin/mipsel-linux-
CROSS_COMPILE:=/usr/local/toolchain_mipsel/bin/mipsel-linux-
KSRC ?=/usr/local/Jupiter/linux-2.6.12
endif
ifeq ($(CONFIG_PLATFORM_RTK_DMP), y)
EXTRA_CFLAGS += -DCONFIG_LITTLE_ENDIAN -DRTK_DMP_PLATFORM  -DCONFIG_WIRELESS_EXT
_PLATFORM_FILES += platform/platform_RTK_DMP_usb.o
endif
ARCH:=mips
CROSS_COMPILE:=mipsel-linux-
KVER:=
KSRC ?= /usr/src/DMP_Kernel/jupiter/linux-2.6.12
endif
ifeq ($(CONFIG_PLATFORM_MT53XX), y)
EXTRA_CFLAGS += -DCONFIG_LITTLE_ENDIAN -DCONFIG_PLATFORM_MT53XX
ARCH:= arm
CROSS_COMPILE:= arm11_mtk_le-
KVER:= 2.6.27
KSRC?= /proj/mtk00802/BD_Compare/BDP/Dev/BDP_V301/BDP_Linux/linux-2.6.27
endif
ifeq ($(CONFIG_PLATFORM_ARM_MX51_241H), y)
EXTRA_CFLAGS += -DCONFIG_LITTLE_ENDIAN -DCONFIG_WISTRON_PLATFORM
ARCH := arm
CROSS_COMPILE := /opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-
KVER  := 2.6.31
KSRC ?= /lib/modules/2.6.31-770-g0e46b52/source
endif
ifeq ($(CONFIG_PLATFORM_FS_MX61), y)
ARCH := arm
CROSS_COMPILE := /home/share/CusEnv/FreeScale/arm-eabi-4.4.3/bin/arm-eabi-
KSRC ?= /home/share/CusEnv/FreeScale/FS_kernel_env
endif
ifeq ($(CONFIG_PLATFORM_ACTIONS_ATJ227X), y)
EXTRA_CFLAGS += -DCONFIG_LITTLE_ENDIAN -DCONFIG_PLATFORM_ACTIONS_ATJ227X
ARCH := mips
CROSS_COMPILE := /home/cnsd4/project/actions/tools-2.6.27/bin/mipsel-linux-gnu-
KVER  := 2.6.27
KSRC := /home/cnsd4/project/actions/linux-2.6.27.28
endif
ifeq ($(CONFIG_PLATFORM_TI_DM365), y)
EXTRA_CFLAGS += -DCONFIG_LITTLE_ENDIAN -DCONFIG_PLATFORM_TI_DM365
EXTRA_CFLAGS += -DCONFIG_USE_USB_BUFFER_ALLOC_RX
EXTRA_CFLAGS += -DCONFIG_SINGLE_XMIT_BUF -DCONFIG_SINGLE_RECV_BUF
ARCH := arm
#CROSS_COMPILE := /home/cnsd4/Appro/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-
#KSRC := /home/cnsd4/Appro/mv_pro_5.0/montavista/pro/devkit/lsp/ti-davinci/linux-dm365
CROSS_COMPILE := /opt/montavista/pro5.0/devkit/arm/v5t_le/bin/arm-linux-
KSRC:= /home/vivotek/lsp/DM365/kernel_platform/kernel/linux-2.6.18
KERNELOUTPUT := ${PRODUCTDIR}/tmp
KVER  := 2.6.18
endif
ifeq ($(CONFIG_PLATFORM_MOZART), y)
EXTRA_CFLAGS += -DCONFIG_LITTLE_ENDIAN -DCONFIG_PLATFORM_MOZART
ARCH := arm
CROSS_COMPILE := /home/vivotek/lsp/mozart3v2/Mozart3e_Toolchain/build_arm_nofpu/usr/bin/arm-linux-
KSRC:= /opt/Vivotek/lsp/mozart3v2/kernel_platform/kernel/mozart_kernel-1.17
KERNELOUTPUT := /home/pink/sample/ODM/IP8136W-VINT/tmp/kernel
endif
ifeq ($(CONFIG_PLATFORM_TEGRA3_CARDHU), y)
ARCH := arm
CROSS_COMPILE := /home/android_sdk/nvidia/tegra-16r3-partner-android-4.1_20120723/prebuilt/linux-x86/toolchain/arm-eabi-4.4.3/bin/arm-eabi-
KSRC := /home/android_sdk/nvidia/tegra-16r3-partner-android-4.1_20120723/out/target/product/cardhu/obj/KERNEL
MODULE_NAME := wlan
endif
ifeq ($(CONFIG_PLATFORM_TEGRA4_DALMORE), y)
ARCH := arm
CROSS_COMPILE := /home/android_sdk/nvidia/tegra-17r9-partner-android-4.2-dalmore_20130131/prebuilts/gcc/linux-x86/arm/arm-eabi-4.6/bin/arm-eabi-
KSRC := /home/android_sdk/nvidia/tegra-17r9-partner-android-4.2-dalmore_20130131/out/target/product/dalmore/obj/KERNEL
MODULE_NAME := wlan
endif
ifeq ($(CONFIG_PLATFORM_ARM_TCC8900), y)
ARCH := arm
CROSS_COMPILE := /home/android_sdk/Telechips/SDK_2304_20110613/prebuilt/linux-x86/toolchain/arm-eabi-4.4.3/bin/arm-eabi-
KSRC := /home/android_sdk/Telechips/SDK_2304_20110613/kernel
MODULE_NAME := wlan
endif
ifeq ($(CONFIG_PLATFORM_ARM_TCC8920), y)
ARCH := arm
CROSS_COMPILE := /home/android_sdk/Telechips/v12.06_r1-tcc-android-4.0.4/prebuilt/linux-x86/toolchain/arm-eabi-4.4.3/bin/arm-eabi-
KSRC := /home/android_sdk/Telechips/v12.06_r1-tcc-android-4.0.4/kernel
MODULE_NAME := wlan
endif
ifeq ($(CONFIG_PLATFORM_ARM_TCC8920_JB42), y)
ARCH := arm
CROSS_COMPILE := /home/android_sdk/Telechips/v13.03_r1-tcc-android-4.2.2_ds_patched/prebuilts/gcc/linux-x86/arm/arm-eabi-4.6/bin/arm-eabi-
KSRC := /home/android_sdk/Telechips/v13.03_r1-tcc-android-4.2.2_ds_patched/kernel
MODULE_NAME := wlan
endif
ifeq ($(CONFIG_PLATFORM_ARM_RK2818), y)
EXTRA_CFLAGS += -DCONFIG_LITTLE_ENDIAN -DCONFIG_PLATFORM_ANDROID -DCONFIG_PLATFORM_ROCKCHIPS
ARCH := arm
CROSS_COMPILE := /usr/src/release_fae_version/toolchain/arm-eabi-4.4.0/bin/arm-eabi-
KSRC := /usr/src/release_fae_version/kernel25_A7_281x
MODULE_NAME := wlan
endif
ifeq ($(CONFIG_PLATFORM_ARM_RK3188), y)
# default setting for Power control
EXTRA_CFLAGS += -DRTW_SUPPORT_PLATFORM_SHUTDOWN
# default setting for Special function
ARCH := arm
CROSS_COMPILE := /home/android_sdk/Rockchip/Rk3188/prebuilts/gcc/linux-x86/arm/arm-eabi-4.6/bin/arm-eabi-
KSRC := /home/android_sdk/Rockchip/Rk3188/kernel
MODULE_NAME := wlan
endif
ifeq ($(CONFIG_PLATFORM_ARM_RK3066), y)
EXTRA_CFLAGS += -DCONFIG_PLATFORM_ARM_RK3066
endif
EXTRA_CFLAGS += -fno-pic
ARCH := arm
CROSS_COMPILE := /home/android_sdk/Rockchip/rk3066_20130607/prebuilts/gcc/linux-x86/arm/arm-linux-androideabi-4.6/bin/arm-linux-androideabi-
#CROSS_COMPILE := /home/android_sdk/Rockchip/Rk3066sdk/prebuilts/gcc/linux-x86/arm/arm-linux-androideabi-4.6/bin/arm-linux-androideabi-
KSRC := /home/android_sdk/Rockchip/Rk3066sdk/kernel
MODULE_NAME :=wlan
endif
ifeq ($(CONFIG_PLATFORM_ARM_RK3399), y)
EXTRA_CFLAGS += -DCONFIG_PLATFORM_ROCKCHIPS
EXTRA_CFLAGS += -DCONFIG_PLATFORM_ROCKCHIPS_RK3399
EXTRA_CFLAGS += -Wno-error=date-time
# default setting for Android 5.0 and later
ARCH ?= arm64
CROSS_COMPILE ?= /rk3328_box_android_8.0_pro/prebuilts/gcc/linux-x86/aarch64/aarch64-linux-android-4.9/bin/aarch64-linux-android-
KSRC ?= /rk3328_box_android_8.0_pro/kernel
_PLATFORM_FILES += platform/platform_rockchips_sdio.o
USER_MODULE_NAME := 8822bs
endif
endif
endif
ifeq ($(CONFIG_PLATFORM_ARM_URBETTER), y)
EXTRA_CFLAGS += -DCONFIG_LITTLE_ENDIAN #-DCONFIG_MINIMAL_MEMORY_USAGE
ARCH := arm
CROSS_COMPILE := /media/DATA-1/urbetter/arm-2009q3/bin/arm-none-linux-gnueabi-
KSRC := /media/DATA-1/urbetter/ics-urbetter/kernel
MODULE_NAME := wlan
endif
ifeq ($(CONFIG_PLATFORM_ARM_TI_PANDA), y)
ARCH := arm
#CROSS_COMPILE := /media/DATA-1/aosp/ics-aosp_20111227/prebuilt/linux-x86/toolchain/arm-eabi-4.4.3/bin/arm-eabi-
#KSRC := /media/DATA-1/aosp/android-omap-panda-3.0_20120104
CROSS_COMPILE := /media/DATA-1/android-4.0/prebuilt/linux-x86/toolchain/arm-eabi-4.4.3/bin/arm-eabi-
KSRC := /media/DATA-1/android-4.0/panda_kernel/omap
MODULE_NAME := wlan
endif
ifeq ($(CONFIG_PLATFORM_MIPS_JZ4760), y)
EXTRA_CFLAGS += -DCONFIG_LITTLE_ENDIAN -DCONFIG_MINIMAL_MEMORY_USAGE
ARCH ?= mips
CROSS_COMPILE ?= /mnt/sdb5/Ingenic/Umido/mips-4.3/bin/mips-linux-gnu-
KSRC ?= /mnt/sdb5/Ingenic/Umido/kernel
endif
ifeq ($(CONFIG_PLATFORM_SZEBOOK), y)
ARCH:=arm
CROSS_COMPILE:=/opt/crosstool2/bin/armeb-unknown-linux-gnueabi-
KVER:= 2.6.31.6
KSRC:= ../code/linux-2.6.31.6-2020/
endif
ifeq ($(CONFIG_PLATFORM_ARM_SUNxI), y)
EXTRA_CFLAGS += -DCONFIG_PLATFORM_ARM_SUNxI
endif
# default setting for A10-EVB mmc0
#EXTRA_CFLAGS += -DCONFIG_WITS_EVB_V13
_PLATFORM_FILES += platform/platform_ARM_SUNxI_sdio.o
endif
ARCH := arm
CROSS_COMPILE=/home/android_sdk/Allwinner/a10/android-jb42/lichee-jb42/buildroot/output/external-toolchain/bin/arm-none-linux-gnueabi-
KVER  := 3.0.8
#KSRC:= ../lichee/linux-3.0/
KSRC=/home/android_sdk/Allwinner/a10/android-jb42/lichee-jb42/linux-3.0
endif
ifeq ($(CONFIG_PLATFORM_ARM_SUN6I), y)
EXTRA_CFLAGS += -DCONFIG_PLATFORM_ARM_SUN6I
EXTRA_CFLAGS +=  -DCONFIG_QOS_OPTIMIZATION
endif
# default setting for A31-EVB mmc0
EXTRA_CFLAGS += -DCONFIG_A31_EVB
_PLATFORM_FILES += platform/platform_ARM_SUNnI_sdio.o
endif
ARCH := arm
#Android-JB42
#CROSS_COMPILE := /home/android_sdk/Allwinner/a31/android-jb42/lichee/buildroot/output/external-toolchain/bin/arm-linux-gnueabi-
#KSRC :=/home/android_sdk/Allwinner/a31/android-jb42/lichee/linux-3.3
#ifeq ($(CONFIG_USB_HCI), y)
#MODULE_NAME := 8188eu_sw
#endif
# ==== Cross compile setting for kitkat-a3x_v4.5 =====
CROSS_COMPILE := /home/android_sdk/Allwinner/a31/kitkat-a3x_v4.5/lichee/buildroot/output/external-toolchain/bin/arm-linux-gnueabi-
KSRC :=/home/android_sdk/Allwinner/a31/kitkat-a3x_v4.5/lichee/linux-3.3
endif
ifeq ($(CONFIG_PLATFORM_ARM_SUN7I), y)
EXTRA_CFLAGS += -DCONFIG_PLATFORM_ARM_SUN7I
endif
endif
ARCH := arm
# ===Cross compile setting for Android 4.2 SDK ===
#CROSS_COMPILE := /home/android_sdk/Allwinner/a20_evb/lichee/out/android/common/buildroot/external-toolchain/bin/arm-linux-gnueabi-
#KSRC := /home/android_sdk/Allwinner/a20_evb/lichee/linux-3.3
# ==== Cross compile setting for Android 4.3 SDK =====
#CROSS_COMPILE := /home/android_sdk/Allwinner/a20/android-jb43/lichee/out/android/common/buildroot/external-toolchain/bin/arm-linux-gnueabi-
#KSRC := /home/android_sdk/Allwinner/a20/android-jb43/lichee/linux-3.4
# ==== Cross compile setting for kitkat-a20_v4.4 =====
CROSS_COMPILE := /home/android_sdk/Allwinner/a20/kitkat-a20_v4.4/lichee/out/android/common/buildroot/external-toolchain/bin/arm-linux-gnueabi-
KSRC := /home/android_sdk/Allwinner/a20/kitkat-a20_v4.4/lichee/linux-3.4
endif
ifeq ($(CONFIG_PLATFORM_ARM_SUN8I_W3P1), y)
EXTRA_CFLAGS += -DCONFIG_PLATFORM_ARM_SUN8I
EXTRA_CFLAGS += -DCONFIG_PLATFORM_ARM_SUN8I_W3P1
endif
endif
ARCH := arm
#CROSS_COMPILE := /home/android_sdk/Allwinner/a23/android-jb42/lichee/out/android/common/buildroot/external-toolchain/bin/arm-linux-gnueabi-
#KSRC :=/home/android_sdk/Allwinner/a23/android-jb42/lichee/linux-3.4
# ===Cross compile setting for Android 4.4 SDK ===
CROSS_COMPILE := /home/android_sdk/Allwinner/a23/android-kk44/lichee/out/android/common/buildroot/external-toolchain/bin/arm-linux-gnueabi-
KSRC :=/home/android_sdk/Allwinner/a23/android-kk44/lichee/linux-3.4
endif
ifeq ($(CONFIG_PLATFORM_ARM_SUN8I_W5P1), y)
EXTRA_CFLAGS += -DCONFIG_PLATFORM_ARM_SUN8I_W5P1
endif
endif
ARCH := arm
# ===Cross compile setting for Android L SDK ===
CROSS_COMPILE := /home/android_sdk/Allwinner/a33/android-L/lichee/out/sun8iw5p1/android/common/buildroot/external-toolchain/bin/arm-linux-gnueabi-
KSRC :=/home/android_sdk/Allwinner/a33/android-L/lichee/linux-3.4
endif
ifeq ($(CONFIG_PLATFORM_ACTIONS_ATV5201), y)
EXTRA_CFLAGS += -DCONFIG_LITTLE_ENDIAN -DCONFIG_PLATFORM_ACTIONS_ATV5201
EXTRA_CFLAGS += -DCONFIG_SDIO_DISABLE_RXFIFO_POLLING_LOOP
ARCH := mips
CROSS_COMPILE := mipsel-linux-gnu-
KVER  := $(KERNEL_VER)
KSRC:= $(CFGDIR)/../../kernel/linux-$(KERNEL_VER)
endif
ifeq ($(CONFIG_PLATFORM_ARM_RTD299X), y)
ifeq ($(CONFIG_ANDROID), y)
endif
#ARCH, CROSS_COMPILE, KSRC,and  MODDESTDIR are provided by external makefile
INSTALL_PREFIX :=
endif
ifeq ($(CONFIG_PLATFORM_ARM_RTD299X_LG), y)
EXTRA_CFLAGS += -DRTW_P2P_GROUP_INTERFACE=1
EXTRA_CFLAGS += -DCONFIG_IFACE_NUMBER=3
#EXTRA_CFLAGS += -DCONFIG_FIX_HWPORT
EXTRA_CFLAGS += -DLGE_PRIVATE
EXTRA_CFLAGS += -DPURE_SUPPLICANT
EXTRA_CFLAGS += -DCONFIG_CUSTOMIZED_COUNTRY_CHPLAN_MAP -DCONFIG_RTW_IOCTL_SET_COUNTRY
EXTRA_CFLAGS += -DDBG_RX_DFRAME_RAW_DATA
EXTRA_CFLAGS += -DRTW_REDUCE_SCAN_SWITCH_CH_TIME
ARCH ?= arm
KVER ?=
ifneq ($(PLATFORM), WEBOS)
$(info PLATFORM is empty)
CROSS_COMPILE ?= /mnt/newdisk/LGE/arm-lg115x-linux-gnueabi-4.8-2016.03-x86_64/bin/arm-lg115x-linux-gnueabi-
KSRC ?= /mnt/newdisk/LGE/linux-rockhopper_k3lp_drd4tv_423
endif
CROSS_COMPILE ?=
KSRC ?= $(LINUX_SRC)
INSTALL_PREFIX ?=
endif
ifeq ($(CONFIG_PLATFORM_HISILICON), y)
EXTRA_CFLAGS += -DCONFIG_LITTLE_ENDIAN -DCONFIG_PLATFORM_HISILICON
ifeq ($(SUPPORT_CONCURRENT),y)
endif
ARCH := arm
ifeq ($(CROSS_COMPILE),)
       CROSS_COMPILE = arm-hisiv200-linux-
endif
MODULE_NAME := rtl8192eu
ifeq ($(KSRC),)
       KSRC := ../../../../../../kernel/linux-3.4.y
endif
endif
ifeq ($(CONFIG_PLATFORM_HISILICON_HI3798), y)
EXTRA_CFLAGS += -DCONFIG_PLATFORM_HISILICON
EXTRA_CFLAGS += -DCONFIG_PLATFORM_HISILICON_HI3798
#EXTRA_CFLAGS += -DCONFIG_PLATFORM_HISILICON_HI3798_MV200_HDMI_DONGLE
EXTRA_CFLAGS += -DRTW_USE_CFG80211_STA_EVENT
# default setting for Android 5.x and later
#EXTRA_CFLAGS += -DCONFIG_RADIO_WORK
# Change active scan time in each channel, unit is ms
#EXTRA_CFLAGS += -DSURVEY_TO_ACTIVE=50
# If system could power on and recognize Wi-Fi SDIO automatically,
# platfrom operations are not necessary.
#ifeq ($(CONFIG_SDIO_HCI), y)
#EXTRA_CFLAGS += -DCONFIG_PLATFORM_OPS
#_PLATFORM_FILES += platform/platform_hisilicon_hi3798_sdio.o
#EXTRA_CFLAGS += -DCONFIG_HISI_SDIO_ID=1
#endif
ARCH ?= arm
CROSS_COMPILE ?= /HiSTBAndroidV600R003C00SPC021_git_0512/device/hisilicon/bigfish/sdk/tools/linux/toolchains/arm-histbv310-linux/bin/arm-histbv310-linux-
ifndef KSRC
KSRC := /HiSTBAndroidV600R003C00SPC021_git_0512/device/hisilicon/bigfish/sdk/source/kernel/linux-3.18.y
KSRC += O=/HiSTBAndroidV600R003C00SPC021_git_0512/out/target/product/Hi3798MV200/obj/KERNEL_OBJ
endif
CONFIG_RTL8822BS ?= m
USER_MODULE_NAME := rtl8822bs
endif
endif
endif
# Platform setting
ifeq ($(CONFIG_PLATFORM_ARM_SPREADTRUM_6820), y)
ifeq ($(CONFIG_ANDROID_2X), y)
EXTRA_CFLAGS += -DANDROID_2X
endif
EXTRA_CFLAGS += -DCONFIG_PLATFORM_SPRD
EXTRA_CFLAGS += -DPLATFORM_SPREADTRUM_6820
ifeq ($(RTL871X), rtl8188e)
EXTRA_CFLAGS += -DSOFTAP_PS_DURATION=50
endif
_PLATFORM_FILES += platform/platform_sprd_sdio.o
endif
endif
ifeq ($(CONFIG_PLATFORM_ARM_SPREADTRUM_8810), y)
endif
EXTRA_CFLAGS += -DPLATFORM_SPREADTRUM_8810
endif
endif
endif
ifeq ($(CONFIG_PLATFORM_ARM_WMT), y)
_PLATFORM_FILES += platform/platform_ARM_WMT_sdio.o
endif
ARCH := arm
CROSS_COMPILE := /home/android_sdk/WonderMedia/wm8880-android4.4/toolchain/arm_201103_gcc4.5.2/mybin/arm_1103_le-
KSRC := /home/android_sdk/WonderMedia/wm8880-android4.4/kernel4.4/
MODULE_NAME :=8189es_kk
endif
ifeq ($(CONFIG_PLATFORM_RTK119X), y)
#EXTRA_CFLAGS += -DCONFIG_PLATFORM_ARM_SUN7I
#EXTRA_CFLAGS +=  -DCONFIG_QOS_OPTIMIZATION
#EXTRA_CFLAGS += -DCONFIG_#PLATFORM_OPS
#_PLATFORM_FILES += platform/platform_ARM_SUNxI_usb.o
endif
endif
ARCH := arm
# ==== Cross compile setting for Android 4.4 SDK =====
#CROSS_COMPILE := arm-linux-gnueabihf-
KVER  := 3.10.24
#KSRC :=/home/android_sdk/Allwinner/a20/android-kitkat44/lichee/linux-3.4
CROSS_COMPILE := /home/realtek/software_phoenix/phoenix/toolchain/usr/local/arm-2013.11/bin/arm-linux-gnueabihf-
KSRC := /home/realtek/software_phoenix/linux-kernel
MODULE_NAME := 8192eu
endif
ifeq ($(CONFIG_PLATFORM_RTK119X_AM), y)
EXTRA_CFLAGS += -DCONFIG_PLATFORM_RTK119X_AM
EXTRA_CFLAGS += -DCONFIG_CONCURRENT_MODE -DCONFIG_FULL_CH_IN_P2P_HANDSHAKE
endif
ARCH := arm
KVER  := 3.10.24
#KSRC :=
CROSS_COMPILE :=
endif
ifeq ($(CONFIG_PLATFORM_RTK129X), y)
EXTRA_CFLAGS += -DRTK_129X_PLATFORM
#EXTRA_CFLAGS += -DCONFIG_P2P_IPS -DCONFIG_QOS_OPTIMIZATION
ifeq ($(CONFIG_RTL8821C)$(CONFIG_SDIO_HCI),yy)
EXTRA_CFLAGS += -DCONFIG_WAKEUP_GPIO_INPUT_MODE
EXTRA_CFLAGS += -DCONFIG_BT_WAKE_HST_OPEN_DRAIN
endif
# default setting for Android 7.0
ifeq ($(RTK_ANDROID_VERSION), nougat)
endif
endif
ARCH := arm64
#KVER  := 4.1.10
#CROSS_COMPILE := $(CROSS)
#KSRC := $(LINUX_KERNEL_PATH)
CROSS_COMPILE := /home/android_sdk/DHC/trunk-6.0.0_r1-QA160627/phoenix/toolchain/asdk64-4.9.4-a53-EL-3.10-g2.19-a64nt-160307/bin/asdk64-linux-
KSRC := /home/android_sdk/DHC/trunk-6.0.0_r1-QA160627/linux-kernel
endif
ifeq ($(CONFIG_PLATFORM_RTK390X), y)
EXTRA_CFLAGS += -DCONFIG_PLATFORM_RTK390X
endif
ARCH:=rlx
CROSS_COMPILE:=mips-linux-
KSRC:= /home/realtek/share/Develop/IPCAM_SDK/RealSil/rts3901_sdk_v1.2_vanilla/linux-3.10
endif
ifeq ($(CONFIG_PLATFORM_NOVATEK_NT72668), y)
EXTRA_CFLAGS += -DCONFIG_PLATFORM_NOVATEK_NT72668
ARCH ?= arm
KVER := 3.8.0
KSRC := /Custom/Novatek/TCL/linux-3.8_header
#KSRC := $(KERNELDIR)
endif
ifeq ($(CONFIG_PLATFORM_ARM_TCC8930_JB42), y)
ARCH := arm
CROSS_COMPILE := /home/android_sdk/Telechips/v13.05_r1-tcc-android-4.2.2_tcc893x-evm_build/prebuilts/gcc/linux-x86/arm/arm-eabi-4.6/bin/arm-eabi-
KSRC := /home/android_sdk/Telechips/v13.05_r1-tcc-android-4.2.2_tcc893x-evm_build/kernel
MODULE_NAME := wlan
endif
ifeq ($(CONFIG_PLATFORM_RTL8197D), y)
EXTRA_CFLAGS += -DCONFIG_BIG_ENDIAN -DCONFIG_PLATFORM_RTL8197D
export DIR_LINUX=$(shell pwd)/../SDK/rlxlinux-sdk321-v50/linux-2.6.30
ARCH ?= rlx
CROSS_COMPILE:= $(DIR_LINUX)/../toolchain/rsdk-1.5.5-5281-EB-2.6.30-0.9.30.3-110714/bin/rsdk-linux-
KSRC := $(DIR_LINUX)
endif
ifeq ($(CONFIG_PLATFORM_AML_S905), y)
EXTRA_CFLAGS += -DCONFIG_PLATFORM_AML_S905
EXTRA_CFLAGS += -DCONFIG_LITTLE_ENDIAN -fno-pic
_PLATFORM_FILES += platform/platform_aml_s905_sdio.o
endif
ARCH ?= arm64
CROSS_COMPILE ?= /4.4_S905L_8822bs_compile/gcc-linaro-aarch64-linux-gnu-4.9-2014.09_linux/bin/aarch64-linux-gnu-
ifndef KSRC
KSRC := /4.4_S905L_8822bs_compile/common
# To locate output files in a separate directory.
KSRC += O=/4.4_S905L_8822bs_compile/KERNEL_OBJ
endif
endif
endif
endif
ifeq ($(CONFIG_PLATFORM_ZTE_ZX296716), y)
EXTRA_CFLAGS += -DCONFIG_PLATFORM_ZTE_ZX296716
# mark this temporarily
#_PLATFORM_FILES += platform/platform_zte_zx296716_sdio.o
endif
ARCH ?= arm64
CROSS_COMPILE ?=
KSRC ?=
endif
endif
endif
ifeq ($(CONFIG_CUSTOMER_HUAWEI_GENERAL), y)
CONFIG_CUSTOMER_HUAWEI = y
endif
ifeq ($(CONFIG_CUSTOMER_HUAWEI), y)
EXTRA_CFLAGS += -DCONFIG_HUAWEI_PROC
endif
MODULE_NAME := rtw_sdio
endif
MODULE_NAME := rtw_usb
endif
MODULE_NAME := rtw_pci
endif
endif
USER_MODULE_NAME ?=
ifneq ($(USER_MODULE_NAME),)
MODULE_NAME := $(USER_MODULE_NAME)
endif
ifneq ($(KERNELRELEASE),)
########### this part for *.mk ############################
include $(src)/hal/phydm/phydm.mk
include $(src)/rtl8822b.mk
endif
include $(src)/rtl8821c.mk
endif
include $(src)/rtl8822c.mk
endif
include $(src)/rtl8814b.mk
endif
rtk_core :=	core/rtw_cmd.o \
		core/rtw_security.o \
		core/rtw_debug.o \
		core/rtw_io.o \
		core/rtw_ioctl_query.o \
		core/rtw_ioctl_set.o \
		core/rtw_ieee80211.o \
		core/rtw_mlme.o \
		core/rtw_mlme_ext.o \
		core/rtw_mi.o \
		core/rtw_wlan_util.o \
		core/rtw_vht.o \
		core/rtw_pwrctrl.o \
		core/rtw_rf.o \
		core/rtw_chplan.o \
		core/rtw_recv.o \
		core/rtw_sta_mgt.o \
		core/rtw_ap.o \
		core/mesh/rtw_mesh.o \
		core/mesh/rtw_mesh_pathtbl.o \
		core/mesh/rtw_mesh_hwmp.o \
		core/rtw_xmit.o	\
		core/rtw_p2p.o \
		core/rtw_rson.o \
		core/rtw_tdls.o \
		core/rtw_br_ext.o \
		core/rtw_iol.o \
		core/rtw_sreset.o \
		core/rtw_btcoex_wifionly.o \
		core/rtw_btcoex.o \
		core/rtw_beamforming.o \
		core/rtw_odm.o \
		core/rtw_rm.o \
		core/rtw_rm_fsm.o \
		core/rtw_rm_util.o \
		core/efuse/rtw_efuse.o
rtk_core += core/rtw_sdio.o
endif
$(MODULE_NAME)-y += $(rtk_core)
$(MODULE_NAME)-$(CONFIG_WAPI_SUPPORT) += core/rtw_wapi.o	\
					core/rtw_wapi_sms4.o
$(MODULE_NAME)-y += $(_OS_INTFS_FILES)
$(MODULE_NAME)-y += $(_HAL_INTFS_FILES)
$(MODULE_NAME)-y += $(_PHYDM_FILES)
$(MODULE_NAME)-y += $(_BTC_FILES)
$(MODULE_NAME)-y += $(_PLATFORM_FILES)
$(MODULE_NAME)-$(CONFIG_MP_INCLUDED) += core/rtw_mp.o
$(MODULE_NAME)-$(CONFIG_MP_INCLUDED)+= core/rtw_bt_mp.o
endif
obj-$(CONFIG_RTL8822BU) := $(MODULE_NAME).o
else
export CONFIG_RTL8822BU = m
all: modules
modules:
	$(MAKE) ARCH=$(ARCH) CROSS_COMPILE=$(CROSS_COMPILE) -C $(KSRC) M=$(shell pwd)  modules
strip:
	$(CROSS_COMPILE)strip $(MODULE_NAME).ko --strip-unneeded
install:
	install -p -m 644 $(MODULE_NAME).ko  $(MODDESTDIR)
	/sbin/depmod -a ${KVER}
uninstall:
	rm -f $(MODDESTDIR)/$(MODULE_NAME).ko
backup_rtlwifi:
	@echo "Making backup rtlwifi drivers"
ifneq (,$(wildcard $(STAGINGMODDIR)/rtl*))
	@tar cPf $(wildcard $(STAGINGMODDIR))/backup_rtlwifi_driver.tar $(wildcard $(STAGINGMODDIR)/rtl*)
	@rm -rf $(wildcard $(STAGINGMODDIR)/rtl*)
endif
ifneq (,$(wildcard $(MODDESTDIR)realtek))
	@tar cPf $(MODDESTDIR)backup_rtlwifi_driver.tar $(MODDESTDIR)realtek
	@rm -fr $(MODDESTDIR)realtek
endif
ifneq (,$(wildcard $(MODDESTDIR)rtl*))
	@tar cPf $(MODDESTDIR)../backup_rtlwifi_driver.tar $(wildcard $(MODDESTDIR)rtl*)
	@rm -fr $(wildcard $(MODDESTDIR)rtl*)
endif
	@/sbin/depmod -a ${KVER}
	@echo "Please reboot your system"
restore_rtlwifi:
	@echo "Restoring backups"
ifneq (,$(wildcard $(STAGINGMODDIR)/backup_rtlwifi_driver.tar))
	@tar xPf $(STAGINGMODDIR)/backup_rtlwifi_driver.tar
	@rm $(STAGINGMODDIR)/backup_rtlwifi_driver.tar
endif
ifneq (,$(wildcard $(MODDESTDIR)backup_rtlwifi_driver.tar))
	@tar xPf $(MODDESTDIR)backup_rtlwifi_driver.tar
	@rm $(MODDESTDIR)backup_rtlwifi_driver.tar
endif
ifneq (,$(wildcard $(MODDESTDIR)../backup_rtlwifi_driver.tar))
	@tar xPf $(MODDESTDIR)../backup_rtlwifi_driver.tar
	@rm $(MODDESTDIR)../backup_rtlwifi_driver.tar
endif
config_r:
	@echo "make config"
	/bin/bash script/Configure script/config.in
.PHONY: modules clean
clean:
	#$(MAKE) -C $(KSRC) M=$(shell pwd) clean
	cd hal ; rm -fr */*/*/*.mod.c */*/*/*.mod */*/*/*.o */*/*/.*.cmd */*/*/*.ko */*/*/*.ur-safe
	cd hal ; rm -fr */*/*.mod.c */*/*.mod */*/*.o */*/.*.cmd */*/*.ko */*/*.ur-safe
	cd hal ; rm -fr */*.mod.c */*.mod */*.o */.*.cmd */*.ko */*.ur-safe
	cd hal ; rm -fr *.mod.c *.mod *.o .*.cmd *.ko *.ur-safe
	cd core ; rm -fr */*.mod.c */*.mod */*.o */.*.cmd */*.ko */*.ur-safe
	cd core ; rm -fr *.mod.c *.mod *.o .*.cmd *.ko *.ur-safe
	cd os_dep/linux ; rm -fr *.mod.c *.mod *.o .*.cmd *.ko *.ur-safe
	cd os_dep ; rm -fr *.mod.c *.mod *.o .*.cmd *.ko *.ur-safe
	cd platform ; rm -fr *.mod.c *.mod *.o .*.cmd *.ko *.ur-safe
	rm -fr Module.symvers ; rm -fr Module.markers ; rm -fr modules.order
	rm -fr *.mod.c *.mod *.o .*.cmd *.ko *~
	rm -fr .tmp_versions *.ur-safe
endif
